Question about Cameras
How do you change the flash settings on the technika 7065
How to set my flash
Posted on Dec 15, 2008
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Computers & Internet
I cant found the driver of my TECHNIKA SH-7065 so i can turn it into a pc camea
I will provide you a link that may help you downloading the driver you need.
Please click HERE to download the driver.
Jul 10, 2011 | Computers & Internet
The item is a technika cr-109ip ipod docking station and clock radio but it has not come with and instruction manual and we cannot figure out how to change the time, the alarm time can change but not the...
1)touch and hold both the M and E touch pads for at least 1 second to enter clock setting mode- the hour digits will now flash
2)set/change the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the hour digit
3)when the hour is set correctly touch the E touch pad to confirm
4)the minute digit will now flash. Set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
5) when the minutes are set correctly touch the E touch pad to confirm
the clock is now set
Dec 25, 2010 | Audio Players & Recorders
Need Vista Home Premium Driver for Technika SH 7065 PC Cam, Thanks.
  • www.techsupportforum.com/.../driver.../229621-drivers-vista-home-premium.html -
Jul 31, 2009 | Cameras
Own a Technika SH-7065 but have misplaced charger for battery....
Hi, just connect to PC using USB cable and tis will charge your camera!
Pingu
Apr 02, 2009 | Cameras
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Memory full
You camera is running off of the internal memory the camera manufacture does not give you much to play with. If you have a memory card in the camera and are still having the same issue going to the setup menu and find memory and set it to auto this will allow the camera to use the memory chip and used the internal memory when it is out. some times you can do a camera reset and it will correct most of the issues.
Mar 24, 2008 | Cameras
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
