Question about Belkin Computers & Internet
F5D9050 SEEMS to be slow making initial connection,also loses connection sometimes when XBOX is used on line with PC
    President:
  • 778 Answers
Sounds like you are running low on Bandwidth, you can check yours here: http://www.speakeasy.net/speedtest/
Especially since it loses connection when your Xbox is online.
Posted on Jul 15, 2008
I have black and white lines running down the screen after I connected it to internet. How do I get rid?
Could be a lose cable, Check the cables connecting to the monitor (screen) and the to PC.
Also, made sure your phone or any other electronic device(s) aren't in close proximity to the screen. They sometimes cause interference.
Jan 07, 2013 | ASUS Computers & Internet
I have an xbox and a ps3 and my xbox has terrible connection to the wifi and my ps3 is connected to the router and has even worse connection thn my xbox! how do i improve my inteernet connection to my...
Sometimes when this happens to my PS3 or Xbox, I turn off my routers for at least 10 seconds then start back up again. Another way to rule out that it is indeed your gaming systems and not lag with your internet connection, I recommend that you run a bandwidth test from your PC first. This will give you an initial understanding of your internet performance. If your Bandwidth test returns a result of a slow connection, this will have a direct impact on your gaming experience. Here is a link to test your bandwidth (or internet connection speed.)
Click here for speed test.
Note: anything below 1mb on your download speed will cause your gaming experience to be poor.
I recommend 3+ meg for optimal performance.
I hope this information helps you.
Regards,
NIco
Jul 09, 2011 | NetGear RangeMax WPN824 Router
Why does my wired xbox controller lose connection?
Sometimes vibrations throw off internal components. Try disabling controller vibration and see if that makes a difference
May 15, 2011 | Microsoft Xbox 360 Controller
Xbox 360 controllers are slow to connect
check where you have the xbox located. try moving it to another place away from other eletronics see if this will speed connectivity.
Apr 23, 2010 | Microsoft Xbox 360 Controller
Xbox 360 loading fault with dotted screen, checkered. freezes on loading screen even. sometimes it can appear there are several lines down the screen aswell so it may be 2 faults.
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Jan 12, 2010 | Microsoft Xbox 360 Console
Windows 7 driver update for Belkin F5D9050
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Dec 29, 2009 | Belkin F5D9050 Wireless G Plus MIMO USB...
Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Sep 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Trying to connect to xbox live,have full broadband signal on my xbox but my xbox wont download an update to get on line, the message says can't download the update.please test your connection in...
If you have a cd burner on your computer you can follow this link
http://www.xbox.com/en-US/support/systemuse/xbox360/console/systemupdates.htm and it gives you full instructions on how to burn the disk and update your xbox. If that does not help with connecting try going to the system tab of your dashboard and run the initial setup. Dont worry you wont lose all your downloads and profiles, it just changes all settings back to the default.
Apr 10, 2008 | Video Game Consoles & Games
XBOX 360 keeps resetting itself
There is a Microsoft KB article on this: http://support.microsoft.com/kb/911152 I would try that and see if that helps. Also try removing and reapplying the faceplate. Did you recently move/bump your 360? If so, I could see the KB article applying to your situation. BTW, what makes me think its user error is the fact that you specify that important 5-10 second window. If a button or something is pressed down permanently, it has a tendacy to be like clock-work, while hardware errors/failures with the 360 seem to be more towards random restarts and failures. If all else fails, just call MS and see what they can do. You may want to repost with exact details of what is going on, your Xbox's condition (dusty?), and what changed to make the event begin.
Sep 28, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
