Question about Microwave Ovens
How to check the fuse in microwave - Microwave Ovens
  • 6 more comments
  • kbdering Dec 27, 2008
    JVM1650BB005 - Where can I find a diagram of how to find the fuse?
  • nparmenti Dec 27, 2008
    I think it is the fuse but do not know where to look for it. Please let me know where to look. Thanks Marie
    I have a JVM1340ww spacemaker and I think the fuse blew. Not sure where to find it. Thanks.
  • in_hoodsport Jan 06, 2009
    Where is the thermal fuze on the GE Spacemaker XL1899? This microwave just "died" and has no power. I have verified that it is not a circuit breaker problem.
  • Anonymous Jan 19, 2009
    GE Spacemaker Model JVM239WV001: Just went dead all around. Circuit-breaker OK and outlet OK. Replaced fuse behind grille on top right.
    Still not working. What's next ? Need help.
  • alanjlazar Jan 19, 2009
    GE Spacemaker Model JVM239WV001: Just went dead all around. Circuit-breaker OK and outlet OK. Replaced Fuse behind grille on upper right. Still not working. What next ? Need help.
  • Anonymous Jan 23, 2009
    Ge Spacemaker JEM25WY 001
    Mfg 1998
    went dead, presumably blew fuse.
    Where is fuse,please? What type?
    And how can I get at it?
    Thanks
  • Christopher McGovern Jan 28, 2009
    outlet is powered up but nothing on mic working. I checked the fuse connected to the pluge and it was still good. Seems like once powers in the circut board no power after.
  • 143 Answers
Take the screws out of the case and look inside to find the fuse.
Posted on Jul 24, 2008
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
Microwave portion malfunction
Did you mean that the microwave oven won't turn on at all?Did you try replacing the fuse?
May 24, 2008 | GE Advantium SCA1001SS Convection /...
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
LG under cabinet microwave (LMV2073ST) overheated. Now no power to unit.
There may be a fuse inside.
Always put a microwave back together to test it. A mobile telephone in the vicinity will also check a microwave for leaks.
Feb 14, 2015 | LG LMV2073ST Stainless Steel 1100 Watts...
How come my over the range microwave does not turn on at all??
Check internal fuse. If it's ok, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. Diagnostics and repair might be quite complicates so better you take it to a repair service. You have some interesting Youtube video tutorials to repair a microwave
Replacing Microwave Fuse Pt1 of 3
Microwave No Power Repair
Microwave Not Turning On Fuse Testing Microwave Troubleshooting Repair
Sep 23, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
It is behaving as if there is no power to the plug. There ias power i checked it.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should start working again
Feb 10, 2011 | GE JE1860 Microwave Oven
No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
Oct 09, 2010 | Viking DMOR205SS Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave has no power
Hi
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Thanks
Rylee
Jan 15, 2009 | Whirlpool MH7135XE Microwave Oven
Microwave oven
Check the wall AC outlet by using a meter or another electrical appliance such as a table lamp. If no power there replace the fuse or reset the circuit breaker.
Does your microwave light up when you open the door?
If not, it could be a bad power cord, on/off switch AC cord or fuse.
Check these first.
If you cannot solve the problem, you'll probably need service.
Hope this helped.
Mar 25, 2008 | Panasonic NN-P794SF Microwave Oven
Microwave Ovens Logo
924 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
