Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink cartridge why when i refilled my ink cartrige, black and magenta my printer says depleted for the blk. and no ink on magenta, it wont let me print, do i need to reset anything on the printer what did i do wrong
Refilled cartridges are a bad idea.
Posted on Jul 17, 2008
    President:
  • 778 Answers
I think you need to open your printers "Properties" and set and apply that new cartridges have been installed to get past the problem. It's been a while but I had to do this with mine last time I refilled them after they showed depleted.
Posted on Jul 15, 2008
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I have Canon multifunction MX310 I was using
press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Canon do not like you to use refills and generic carts so the function for detecting the remaining ink level will be disabled
Jun 19, 2010 | Canon PIXMA MX310 All-In-One Printer
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have replaced both the color and black ink cartriges, however the printer is giving me the "color ink low" indication and a check ink u163 blk alarm. We have reset the cartriges to no avail.
Per the Canon.com troubleshooting guide found on THIS WEBSITE, it would be recommended to ensure that you have the proper cartridge for your printer. Also, double check that you have fully seated in the cartridges and that they align as they should. Lastly, it is important that you are using Genuine Canon ink cartridges to ensure longer printer life, not void any warranty you may have remaining on the printer, and most importantly to ensure proper communication with the actual cartridges.
Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
The cyan and magenta cartidges have run out but I cannot print in black only, since a staus window appears telling me to replace cartridge the cyan and magenta and will not let me continue to print in...
You can't print in black only mode because printer need all cartridges not empty to initialized and working.Don't try to refill this cartridges, it's have a chip and you need to reset it too.Just look in your are for non OEM ink cartridges.Thea are 2-3 times cheaper.
Nov 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Cant remeber the ink cartrige #
Hello, there are two ink cartridges for this printer, 336 Black & 337 Color,the cheapest way to buy these is at costo,Please do not refill your old ink cartridges as the printer will on most ocassions tell you to remove the faulty cartridge, however you may get away with a refill only once. I changed to a Brother MFC it was easier to install,prints faster,it has fax,scan,copy phto capture, you will need to buy use printer lead for this machine as it does not come supplied, the bonus of having the Brother MFC 235C is that the 4 ink cartridges are half the price of one HP Black Cartridge,check out www.999inks.co.uk
Jul 12, 2008 | HP Photosmart 4180 All-in-One Printer
Cannon IP1800 Ink Refill
need to know how to refill the cartridges. I don't see a place to refill them. It is cheaper for me to buy a brand new printer than it is to buy the new cartridges when the ink runs out. Thats crazy.
Nov 27, 2007 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Smart base MPC 400 Printer
This printer needs these cartridges: -
1. (BCI-3eB) Black Ink Cartridge,
2. (BCI-3eC) Cyan Ink Cartridge
3. (BCI-3eM) Magenta Ink Cartridge
4. (BCI-3eY) Yellow Ink Cartridge
I think you need to clean your cartridge connectors with alchohol and retry.
Nov 21, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
407 people viewed this question
Seeker5211
Seeker5211
