Question about Panasonic KX TG1000N Cordless Phone
KX-TG1000N new handset 1
I have a new handset 1. How do I clear the base so it will allow a new handset 1 to be registered?
    Problem Solver:
  • 6 Answers
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Posted on Dec 21, 2008
    How can i register my hanset. it says error.
    Please use the below link to assist you with handset registration.
    http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
    May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
    How do i sync my panasonic phones cordless kx-tga810
    335 is the magic code when you want to remove a previous handset or base station registration!
    Handset:
    1 " (middle soft key) i L i #
    2 Enter "335".
    3 "Cancel Handset" i #
    LThe numbers of all handsets
    registered to the base unit are
    displayed.
    4 Select the handset(s) you want to
    cancel, by pressing the desired handset
    number. i #
    5 "Yes" i # i {ih}
    Base Station:
    A handset can be registered to a maximum
    of 4 base units. A handset can cancel a base
    unit that it is registered to. This allows the
    handset to "forget" the base unit.
    1 " (middle soft key) i N i #
    2 "Registration" i #
    3 Enter "335".
    4 "Cancel Base" i #
    5 Select the base unit(s) you want to
    cancel, by pressing the desired base unit
    number. i #
    6 "Yes" i # i {ih}
    Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
    My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
    I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
    Registering a handset to the
    base unit
    The supplied handset and base unit are
    pre-registered. If for some reason the
    handset is not registered to the base
    unit, re-register the handset.
    1 Handset:
    {MENU}
    2 {V}/{^}: "Initial setting"
    {OK}
    3 {V}/{^}: "Registration"
    {OK}
    4 {V}/{^}: "HS registration"
    {OK}
    5 Base unit:
    - KX-TG4011 series:
    Press and hold {LOCATOR} for
    about 5 seconds. (No registration
    tone)
    - KX-TG4021/KX-TG4071 series:
    about 5 seconds until the
    registration tone sounds.
    If all registered handsets start
    ringing, press the same button to
    stop. Then repeat this step.
    The next step must be completed
    within 90 seconds.
    6 Handset:
    Press {OK}, then wait until a long
    beep sounds.
    Note:
    While registering, "Base in
    registering mode" is displayed on
    all registered handsets.
    When you purchase an additional
    handset, refer to the additional
    handset's installation manual for
    registration.
    See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
    Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
    I have Panasonic KX-TG6051M cordless phone. I have been using it for years with no problems. I now get the message:"No link to base. Move closer to base, try again." I have read the user manual...
    Hello! Have you re-registered the handsets? If not go to page 39...If you have re-registered the handsets...Pull the batteries for 1 hour...reinstall batteries...allow handsets to set in the cradle for 1 minute then test...
    Guru...Saailer
    Jan 01, 2011 | Panasonic KX-TG6051M Cordless Phone
    Sync a new handset to kx-tg5632 phone
    This works on MY panasonic; May work on yours too!
    The included handset and base unit are
    preregistered. If for some reason the
    unit, register the handset.
    1 Handset:
    {MENU} i {0}{0}{1}
    2 Base unit:
    Press and hold {LOCATOR/
    INTERCOM} until the IN USE
    indicator flashes.
    LAfter the IN USE indicator starts
    flashing, the rest of the procedure
    must be completed within 1
    minute.
    3 Handset:
    Press {OK}, then wait until a beep
    sounds.
    4 {OFF}
    Registering an additional handset
    See page 5 for information on the
    available model.
    Start from step 2.
    Dec 29, 2008 | Panasonic KX-TG5632 Phone
    Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
    Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
    Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
    New Handset 1
    well clea the base, you didnt leave much for us to help you on mate.
    Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    A busy signal
    Hi Kevin,
    Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
    Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
    Panasonic kx-tg1100
    STEP1:
    On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
    This will discard the registration of the handset to any base.
    STEP2:
    Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
    NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
    After you finish all the above, hold down the "PAGE" button for about 5 secs.
    You are now done!!!
    Good luck
    Simos
    Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
    Restting the phone handset number
    I would suspect that you need to de-register both 3 and 4 at the same time before re-registering them. This probably will not work if the base unit still thinks phone number 2 is out there somewhere. It would need to be de-registered as well for the others to move up a notch. I did read the process for de-registering somewhere on the web, don't remember where, just that it involves removing/installing the battery and punching some buttons.
    Jul 28, 2007 | Panasonic KX TG1000N Cordless Phone
    Panasonic KX TG1000N Cordless Phone Logo
    599 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
