Question about Motorola Mobility RAZR V3i Cellular Phone
No indication of charging after connecting to usb
I down loaded some pictures from my cell phone to pc through usb. after that i try to charge through the charger there is no indication of charging. now i have doubt
1. whether my battery become dead or not?
2 how to charge my phone after this incident?
by jk
  • 2 more comments
  • kumarsudhasr Jul 15, 2008
    thanks for your solution.
    it is charging through my pc
    shall i continue to charge like this?
    if doing so continuously will the phone get spoiled?
  • newman547 Jul 15, 2008
    not charging in both th ways-by using charger and through pc also
  • nesretiep Oct 29, 2008
    hello.
    my phone is 2 and a half years old.
    the battery has gradually weakend, but suddently it went totally dead.
    when i try chargin, it shows the green lightning fore about 5 seconds, trys to turn on and then it dies.
  • sergioroc Dec 17, 2008
    i have the same problem my cell phone is not charging nevertheless i the battery indicates it is charging but it is doing the other way arround it is uncharging the phone any fix i can do
Newman,
Try the 2nd step and let me know the result.....
Posted on Jul 16, 2008
  • 48 Answers
Kumar,
Try the followings:
1. Plug the phone back to the pc and see if it will charge it. Or if it would beep when a cable is plugged to it. If I'm not mistaken, the driver for your phone should charge it when plugged to pc.
2. If nothing happened from doing the above advice, then get a toothbrush, dip it rubbing alcohol and brush both the phone's charging port and the charger itself.
Best of luck....
Posted on Jul 15, 2008
  • Vincent Au Jul 15, 2008
    Absolutely not...your phone and battery will be fine. Glad it worked....
Rethink possible loop when I power up
Try this:
•Connect the phone to your computer with a USB cable that came in the sales package with your Lumia phone. If the battery has not been used for a long time, to begin charging, you may need to connect the cable, then disconnect and reconnect it.
•Press and hold the Power button for 10 seconds, and then press to turn on your phone again.
•Your PC should detect your phone when it is connected using a USB cable, if this is not happening you can manually switch the phone into specific mode following these steps:
1. Disconnect your phone from the USB cable.
2. Hold down the camera button.
3. Continue holding down the camera button and connect the USB cable between your phone and PC.
4. Continue holding down the camera button until you see the connect-to-computer screen on your Lumia phone display.
5. Release the camera button.
6. The Zune software on the PC should automatically detect your phone now and charging indicator appears on the display.
If the tricks above does not help, you will need to contact your local Nokia Care. You can find details by clicking the Contact us link in the support pages of the Nokia website for your country.
Note: Your battery has been partially charged at the factory but when taking your new device into use, please keep the charger connected for 30 minutes. It is recommended to use original charger (AC-16).
Aug 10, 2013 | Android Zte-z990
Samsung S3370 charging problem
Hello"":":
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 21, 2013 | Samsung S3370 Cell Phone
Phone won't charge
First Option:
Second Option:
Jul 28, 2012 | Pantech Pursuit Cell Phone
Razor Phone wouldn't charge...battery dead, so I replace with new battery. It still will not indicate that battery is charging. I tried several outlets to plug in charger. Still no charging. Phone...
Sounds like you may have a connection problem where the charging cable plugs into the phone. Not much can be done except to get a new phone. Those micro USB/USB style connections last a long time, but once a pin is bent up it is game over. Sorry!
Mar 03, 2011 | Motorola Mobility RAZR V3
Lg km335 charging problem how to service
First Option:
Second Option:
Oct 26, 2010 | LG Cell Phones
Have blk moto razr v3a cell phone. when connected
down load motorola phone tools from www.modmymoto.com the proper drivers will load and youll be fine
Mar 02, 2010 | Motorola Mobility RAZR V3a Cellular Phone
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
W810i doesnt turn on or connect via usb
Charge the phone until it has finished charging, The first thing to do is to make sure that the phone is charged. Attach the charger and charge the phone for about 2.5 hours. Please note that the battery icon may not appear until after the phone has charged for 30 minutes. When the battery icon has stopped “flashing” the phone is fully charged.
Jan 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Unable to charge
There could be corrosion on the charger, or the connection on the phone? If so, remove the battery and clean them both with a toothbrush and Isopropyl Alcohol. The phone may have gotten wet? Check behind the battery, there is a water indicator. Its normally white, if its gotten wet, it will be red. Best of Luck.
Sep 14, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
148 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
