Question about Philips GOGEAR SA6045 MP3 Player
I just got done repairing it and have a question
I just got done repairing and when i first took it off the usb port i turned it on and it went to a blank screen....but whem i turned it on again it worked........but when i went to go and sync some more files i noticed that i had 1.8 mb or gb left and i had alot more memory on it i loose all that memory or dont i????
  • got money Jan 30, 2009
    it wont load on to my computer
  • 8,596 Answers
Reformat the player inside Windows Media Player
Posted on Aug 14, 2008
Last friday i took some pictures and transfered them to my pc as i have done for the last 18 months. Over the weekend i took some more pictures. I went through exactly the same routine in connecting he...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 25, 2010 | FUJIFILM Finepix S1500fd Digital Camera
I have the seagate 500 gb p/n 9nk2AL-510 and I went to go use it the other day and say that the usb port on the back of it has come loose. I am unable to plug a usb into it now. Is there any way to fix...
The usb port probably needs to be re-attached to the board, it would likely with have to be soldered.
You may also be able to remove the actual drive from the external enclosure, look online for info on that.
Jan 12, 2018 | Seagate Free Agent Go Small 12 GB USB...
I have a motorola v3ire . I turned on my phone one day and entered the videos column and it froze,so i took the battery out and put it back in and pressed the power button. When i turned it on it went to...
Hello my friend,this is firmware problem.You can try update or reinstall firmware by your own or take it to a repair shop.For updating the firmware you will need the your phone`s USB cable, a computer,the firmware,flash tool(like PST).But if you don't want to loose your warranty or to risk it take it to repair shop.
Feb 03, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
Tried uploading pics on computer now my camera wont turn on or off...did i break there a virus???
I had the same problem. I took the battery out for 30 seconds and put it back in. I then turned it to the view mode, and turned the camera on. Hope this helps.
Oct 14, 2008 | Sanyo Xacti VPC-T700 Digital Camera
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
Camera wont switch on (z1 dimage.)
This happened to me too, today! I can't turn on my camera and the usb port is stuck inside the camera (can't plug it in, etc). It's easter, so much for taking photos.
Dec 28, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Usb port
yes you are but you may not have done it properly so you should take it to a professional service center or technician and have them do the repair for you.
Aug 23, 2007 | Motorola Mobility RAZR V3
RCA TV F36718 with V-port
That crackly sound could be the flyback transformer sizzleling. if thats the case the horiozontal output transistor is probably bad as well. This repair should be done only by a quilified service person and shouldnt cost over 200 bucks if that much UNLESS of course it was the power sullpy shorting out but most likly in this set what i mentioned. Good Luck
May 18, 2006 | RCA F36718 36" TV
Philips GOGEAR SA6045 MP3 Player Logo
132 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
