Question about Photography
Mounting camera on Fotomate Tripod
I have bought a Foromate Tripod.
The screw with threads on the top is where i am supposed to fix the camera. However, when i load the camera on top of it and rotate it, it never comes to a perfect fit. The screw otherwise is also loose. Is it a problem with the tripod?
  • a6n95 Oct 04, 2008
    I cannot place camera on to the shoe dose not fit
    Problem Solver:
  • 7 Answers
Try adding a flexible filler, such as cork or card stock, or a few buisness cards work as well at times. Cork and card stock are both avaible at a hobby store. Place the mounting bolt through the filler, and snug it up. it should fill the gap you have between the camera and plate. Also take care of the sloppyness of the screw. Good luck.
Posted on Aug 04, 2008
Does the company that makes this tripod sell the small square part that screws into the camera?
Tripod quick mount plates (the part that is secured to the camera) are specific to tripod manufacturer. A tripod without a mating mounting plate is pretty much worthless as there is no way to mount the camera to it.
You will need to contact the manufacturer (or a reputable camera store) and provide the model of your tripod and the size of the threaded mount in you camera - most are either 1/4" or 3/8".
Apr 16, 2015 | Photography
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
Fujifilm s5000 battery door broken
i broke mine a couple of years ago and fixed it by drilling and tapping two holes to suit 6-32 x 11/4" bolts as shown in the attached photo... one of the holes had to be enlarged to suit 6mm x20 because the thread is in a very flimsy area and had stripped
BTW the battery cover doesnt have to be removed from the camera as is shown in the photo! the photo was taken after i disassembled the camera for another repair
it works well with a couple of provisos...
1- the bolt heads may get in the way of mounting the camera on some tripods without modification
2-not as quick to change the batteries
3- dont screw the bolts down too tight - or the threads will strip
before this method i made a metal plate, the same shape as the base of the camera and used the camera tripod socket to attach it... thus keeping the battery door closed [ the advantage of this was that i could drill and tap a thread to attach the lot to a tripod - and the tripod mounting hole could be ia the centreline of the lens - making panoramas easier]11_28_2011_10_48_37_am.jpg
Nov 22, 2011 | Fuji FinePix S5000 Digital Camera
I have a QS-TM and I want to know if there is an attatchment to let me use this tripod for a canon camera?
Tripod mounts are standard size for most cameras, there are strictly speaking 2 sizes but it is unusual to find a modern camera with the wrong size; it should screw directly into the camera (assuming you have a "standard" mounting plate with the tripod!) If it is too large/small you need an adapter, 3/8" to 1/4" or vice versa, but that would be unusual. Most 35mm camera bodies accept a 1/4" diameter, 20 thread-count screw
Jan 11, 2011 | Quantaray Photography
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Need parts list VPT 360SE tripod
'camera mounting scrwe'..any good camera store or online... samy's camera for example
Dec 02, 2008 | Vivitar VPT-360 PROFESSIONAL FLUID-ACTION...
How to fit canon s5is on a tripod stand (fotomate)?
I'm not sure what you're asking. There is a threaded tripod socket on the bottom of the camera. You just screw the tripod into this socket. Is that what you were asking?
Nov 07, 2008 | Canon PowerShot S5 IS Digital Camera
I purchased a second hand Miranda TP20 tripod from a charity sale for a few pounds. The screw plate mounting is missing fromn the top of the tripod - where can I purchase the part from?
the giottos 6E01 quick release plate will fit snug. i bought one for my miranda tp20 today. you can get them from harrison cameras or warehouse express.
Nov 06, 2008 | Vivitar Pink Vivicam 3188 Camera Great...
Mounting bracket
added a spacer made from a truck inner tube. the screw from the tripod still has 2 full threads threading into the bracket on the telescope.
Sep 23, 2008 | Optics
Unable to unscrew camera from mounting plate tripod
The mounting plate may have a small pin with a spring to fit certain kinds of cameras.
Don't try to twist the plate off the camera, that may damage the bottom of the camera.
Instead, the plate should have a slotted screw in the bottom that screws into the camera. Unscrew the bolt with a good screwdriver.
Hope that helps.
Jul 26, 2008 | Kodak EasyShare C875 Digital Camera
Photography Logo
902 people viewed this question
Top Photography Experts
Are you a Photography Expert? Answer questions, earn points and help others
