Question about MSI Wireless-G RG54G3 Router
My wired pc keeps discconecting from internet
I have one pc and and a laptop connected via a wireless MSI router (RG60se) The pc is wired connected while the laptop is wirless connected. My problem is that the pc keeps disconnecting from internet while i have no problem with the laptop. can anyone help???Thanks
    Scholar:
  • 174 Answers
Check for wire loose connection and then any time setting for your dhcp connection. If they are ok check your network connectivity do as follows.
Startup
run
type cmd
at the prompt type ping <your router ip address> -t
kepp watching the reply
use your computer as normally and check when it gets disconnect by watching above
may be some corrupted program send packets in an un usual rate (it can be virus/trojan) so the router blocks those port and your computer disconnect from the network.
Rather from all the above change the PCI Network adapter replace with a new network card.
Hothawk
Posted on Jul 15, 2008
Please advise where to download the firmware for MSI router RG60se ? thanks
http://faenl.msi.com/index.php?dir=Networking/RG60SE/
Enter the firmware folder, then click on the rg60se-up.rar.
Jun 24, 2011 | Computers & Internet
Msi 108 wireless router rg60se ip adress needed
on this page you can read the user manual:
http://www.scribd.com/doc/33684983/MSI-RG60SE
The default IP address is 192.168.1.1
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Apr 10, 2011 | MSI Computers & Internet
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
Helo, i hope some one can help me... i dont know much about router`s anyway a few day ago i try to update my firmware router. My router is MSI RG60SE... and update for firmware i download from some site...
if you can see the router page, then your pc can see the router. go to settings on the router page and follow reset steps.. also routers are next to free now adays, goodwill has a ton of them for like 5 bucks each.
May 02, 2017 | MSI RG54GS Wireless Router
I have internet connection but my laptop will not connect
Check your connections. 1. Wired: directly connected to the modem (not the router) If this works, the router is the issue. 2. Wired directly to the router If this works then wireless is the problem 3. Wireless Check Key for accuracy, Upper and lower case matters. Check that your router does not have MAC address restrictions 4. Clear the cache on the laptop IE. Use the Options menu to clear this.
Dec 12, 2009 | MSI U120-024US Notebook
Wireless internet
try to switch off your wireless adapter for 1min and switch on it again, once switch on your computer should look for other near connection and the notice will prompt you regarding found wireless network. if no found there is problem with your wireless configuration.
try to this 1st and give me comments if the problem still exist.
Nov 25, 2008 | MSI Wireless-G RG54G3 Router
Help?
Something internally died. if you are willing to start replacing chips inside the thing. let me know the part numbers from the chips.
If you dont want to get into surface mount soldering I would suggest canning the thing or EBAYing it as parts.
Apr 30, 2008 | MSI Wireless-G RG54G3 Router
Disconnection of Internet
How are you connected to the internet? Is it perhaps a DSL that needs to have the PPPoE login credentials sent occasionally?
Dig into the config pages for your router and find the option for keeping the connection alive or active, that option should be near the login options for your PPPoE account.
Also consider having the router perform the login rather then your computer or the DSL itself, as most routers are better at handling the login procedure then PC's or modems.
Apr 20, 2008 | MSI Wireless-G RG54G3 Router
Cannot access to router IP
This is presumably because you cannot remember the password. All routers have a reset button which will reset to the factory defaults. Should tell you how to do this in the manual.
Apr 12, 2008 | Arris SURFboard 2.4GHz Wireless Cable...
Iam trying to connect my laptop to the innet. i have wrt54g router.
Hi jjroyc
Let's see if we can get your laptop connected to the Internet.
First, I have some questions and a few instructions for you.
(01) Is this a new (to you) router?
(02) Do you already have one or more computers connecting successfully to the Internet using this router?
(03) If yes, are any of them connecting wirelessly?
(04) Have you recently (at another location for example) successfully connected this laptop to the Internet? If so, did you connect it "wired" or "wirelessly".
(05) Are you trying to connect your laptop to your router "wirelessly" or "wired"?
(06) If you are trying to connect the laptop wirelessly, turn off your laptop's wireless radio and connect the laptop to the router "wired" instead (using an "Ethernet Patch Cable"). Once we've established that the laptop is capable of connecting to the Internet via the simpler "wired" connection, then we'll move on to the more complex wireless connection.
(07) Please, go HERE to download the manual for your particular router. You will need to determine the version number of the WRT54G model 1st. There are instructions there that will guide you through this.
BJ
Apr 03, 2008 | Computers & Internet
MSI Wireless-G RG54G3 Router Logo
186 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
