Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave vent fan replacement.
My problem is that I need to replace the plastic squirrel cage blower fan on my microwave. I need to replace it because it melted when it sucked in flames due to a hot pan that caught on fire when it was left unattended. When I removed the fan from the motor and turned on the vent, the motor still worked. I found out that the fan assembly has a Samsung part number SMV-260UA and it is also used by Frigidaire. I also found out that the unit is very expensive, $150, from GE parts and only to replace the plastic blower fan. Thanks for your help. Can't find the squirrel cage plastic blower fan. need to replace. my model # is JVM140H002 GE space saver over range microwave oven. can you suggest a resource for that part?
  • GE Master
  • 8,973 Answers
The part # SMV-260UA runs just under $60 from SamsungParts, depending on which of three versions you choose. You can find them here.
And a simple Google search shows quite a few hits for "SMV-260UA" and they seem to run about $40, assuming the listings aren't bogus - as so many search results are.
I have a few "new old stock" and used vent & cooling fans here.
I would be happy to supply one whole or just the blades if you like.
Just tell me the dimensions: diameter of the shaft hole and the length and diameter of the "squirrel cage" itself and I'll see if one of mine would work.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
How do you replace the damper switch on a Kenmore microwave, model 721.86013010
Microwave Vent Damper Replacement - GE ... - YouTube
? 3:15
https://www.youtube.com/watch?v=9sQco-DIqQ8
Nov 25, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the vent damper is if it i... ... video is applicable to the following brands ...
How to change the direction of a blower fan for an over the ...
? 1:45
https://www.youtube.com/watch?v=yhvuNOVN0R4
May 8, 2012 - Uploaded by Sparky Channel
For a great price on a Whirlpool microwave: Amazon.com: ... Howto change the direction of a blower fan for ...
Kenmore Microwave Parts - RepairClinic.com
Jan 21, 2016 | Kenmore Microwave Ovens
Microwave fan/vent is excessively loud. How do I
Most vent hood fan motors don't need any maintenance. Over time, the motor and bearings may become stiff because of the constant heat, humidity, and grease to which they're subjected.
Also over time, the blower wheel gets greasy and dirty, which can slow down the fan or cause vibration. Remove the wheel and clean it with a degreaser. Then, if the fan is still slow or if it vibrates, you need
Microwave ovens heat by bombarding the food or liquid in the oven with super-high-frequency microwave sound energy. If there's no food or liquid in the oven to absorb the microwave energy, the energy can feed back to the microwave itself, which can permanently damage the internal microwave antenna (magnetron).
Jul 01, 2009 | Microwave Ovens
Squirrel came down vent pipe and ate a hole in fan wheel how do i replace it
take the squirrel and put it back in the vent pipe,then put a piece of screen over the opening,yes you can,call the manufacturer for prices
May 04, 2015 | In Microwave Ovens
Where is the diode located on a whirlpool microwave
It is usually located right next to the high-voltage capacitor. BE CAREFUL! YOU ARE TREADING IN VERY DANGEROUS TERRITORY! MAKE SURE THE MICROWAVE OVEN IS UNPLUGGED AND WAIT 5 OR MORE MINUTES BEFORE YOU GO POKING AROUND IN THERE. Note: In some older microwave ovens, those with a vertically-mounted squirrel-cage cooling fan, the HV diode was located inside the fan housing.
Oct 19, 2014 | Whirlpool Microwave Ovens
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Converting the vent fan on a GE Combination Oven
is your house vent connected properly? no restrictions?
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Sep 11, 2009 | GE JVM1750SMSS Microwave Oven
Fan vents
Most microwave oven fan systems can be rotated for either back or top venting.. This can be done by removing a few screws and rotating the blower housing to the position you need and screwing it back in place.. Hope this helps..
Aug 30, 2008 | GE Microwave Ovens
First of all, if it's just the plastic (nylon) fan blade that's melted, most any fan blade should work. I'd take the blade and motor to a local appliance parts shop and see if they have just a blade assembly that would fit. Normally the shaft diameter is standard and the only consideration is to get a blade assy whose outside diameter and thickness are the same or a little less than the original. Concerning the original part # you gave there are 3 Samsung parts that match up on http://www.samsungparts.com : Part Number Description Specification Price DE31-10178A MOTOR-VENTILATION SMV-260UA,120V,60Hz,31 $67.78 DE31-10178B MOTOR-VENTILATION SMV-260UA-1,-,-,-,-,-, $70.09 DE31-10178E MOTOR VENTILATION SMV-260UA-N,-,-,120V60 $67.87 Lastly, if there happen to be any numbers on the blade assembly itself, you can check them to see if they're good numbers at http://www.samsungparts.com Good luck!
Dec 02, 2006 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
691 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
