Question about HP Office Equipment & Supplies
Scanjet G4050 will not scan photos. I get the message,an error occured communicating w/scanning device. So I preformed every operation trouble shoot section suggested without results.
    Problem Solver:
PRODUCT STILL UNDER WARRANTY. THANK YOU
Posted on Jul 16, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Hp 3500C communication error
Restart the PC and the scanner and try again. Make sure you installed the right drivers, make sure that the PC see's the scanner, check devise MGR and look under printers, interface devise.
Apr 03, 2013 | HP ScanJet 3500C Flatbed Scanner
Unable to scan from front pannel button on HP G4050
try scanning by conneecting it to the computer and installing the program of the scanner then you will be able to do it from you computer
Feb 27, 2013 | HP Scanjet G4050 Flatbed Scanner
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
HP scanjet 3970will not operated with vista o/s,
Decided I would be spending more time and effort than this scanner was worth. I went and purchased an Epsom. My plan is to rid my house of everything HP. They are not the company they were for so many years, must be the cost accountants are running the show.
Oct 31, 2009 | HP ScanJet 3970 Flatbed Scanner
Scanjet 4890 prepared to scan, but will not work
Uninstall the Driver Software, switch off the Computer and reinstall the driver software again. This should work.
S. Mohan
Oct 12, 2009 | HP Scanjet 4890
Windows XP Pro Service Pack 2.0 not recognizing HP Scanjet 2300c
Check the cable and go to HP site and get the latest drivers
Mar 16, 2009 | HP Office Equipment & Supplies
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
I have recently purchased a HPScanjet G4000 scanner to scan slides. I have successfully scanned my slides into the computer but I don't know how to transfer them to a DVD
Hai...
I hopes that ur HP Scanjet's driver,
when ur scanned photo or other file just specfic path to save ur file.... Before must u have a CD-writer software like Roxio and Nero.,
and also insert ur Blank CD....
If solved ur problem by me and other person jsut inform me at mani@merittech.co.in
"Do not forgot to rank it"
Thanks and Regards.,
//anikandan
Dec 18, 2008 | HP Scanjet G4050 Flatbed Scanner
70 people viewed this question
Ben Johnson
