Question about Refrigerators
Ice dispenser in door- won't deliver whole ice
The in-door ice dispenser will not deliver whole ice cubes, regardless of my selection for crushed or whole. when selecting whole, it delivers crushed, but there is a loud buzz when actuating the mechanism and crushed is delivered.
I think it may be the solenoid that actuates the rod-arm that moves the crush blades in and out of position. With door open, I held the door switch down and tried to dispense whole cubes. I could see that the lever/ rod-arm was not being pushed up by a plastic foot that should do so to change from crushed to whole. what say you? can I buy that part? if so where?
  • dlh4180 Jul 25, 2008
    My ice dispenser only dispenses water..when in .the cubes and crushed ice mode it just makes a buzzing noise. wont make ice. I noticed the freezer door was ajar the next morning. so I turned down the temperature to make it colder, 1 day later...still no ice.
  • hwy505
    hwy505 Sep 06, 2008
    Same problem here - now to find a new solenoid and assembly instructions.
Dear Sir,
I have purchased a whirlpool refrigerator on dt.05.11.2006 from M/S.Ganesh Enterprises, Angul bearing Invoice No. 335. last few days the main door of the refrigerator is not working properly. A part is broken from the door(clamp). Inspite of repeated contact and reminder the dealer have not taken any action till today and telling that the parts is not available.
I am very much dissatisfied with the service of the dealer. Therefore I am request you Sir, kindly look into the matter and necessary action in this regard please be taken.
Thanking You,
Yours faithfully,
06764-232367, 234667
Posted on Jul 15, 2008
My Maytag Fridge Ice Dispenser stuck on crushed ice, so no whole cubes can dispense. What can I do?
If you look at the bottom out side area of the ice cube bucket/auger assembly, you will see a metal rod going front to back. That is the shift rod for cubes/crushed ice. Make sure it is free. Then look at the back of the refrigerator where the end of that rod goes into a square hole. There is a magnetic solenoid in that hole that shifts the rod for selection. The solenoid coil is either bad, unplugged, or for some reason stuck and not shifting that rod. That's where the problems is located.
Apr 12, 2015 | Maytag Refrigerators
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Ice maker only crushing ice not making cubes something about reversing piston
Hi and welcome to FixYa, I am Kelly
Use this manual to help you sort out the problem: (8.43 mb)
The motor is now located on the freezer door
in a foamed-in-place enclosure under the "dispenser
bubble" area of the inner door panel.
The motor is mounted to a plastic mounting
bracket, which, in turn, is mounted to the enclosure
with four mounting screws.
The motor operates on 115 volts DC (115 volts
AC is delivered to the motor, where it is converted
within the motor assembly to DC). This
gives the motor a higher RPM than the earlier
dispenser motors, and results in a faster ice
delivery rate in both the cubed and crushed
Crushed ice is delivered by turning the motor
in a clockwise direction, and cubed ice is delivered
when the motor turns in a counterclockwise
See pages 36 - 40 (starts on printed page 5-12) for checking the motor and the switch pack.
This will deterime what has failed.
Thanks for choosing FixYa,
Jul 22, 2011 | Maytag MSD2758GEW
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
My Frigidaire Electrolux refrigerator ice dispenser is dispensing chrushed ice regardless of whether the ''crush'' or ''cube'' option is selected. The icemaker is working. How to diagnose the problem? The...
Open the freezer door. Pull the ice bin OUT and then push it back IN until it locks in place. They will "jump the track" at times,causing crushed ice regardless of the settings. Look under the ice bin. You will see a metal rod it goes inside a yoke in the back of the freezer. Make sure it is inside,not under or over the yoke.
Oct 08, 2009 | Electrolux Refrigerators
Door ice dispensor will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
