Question about Linksys WUSB300N Wireless Adapter
Can get Local Connection but can't get on internet!
I recently installed a WUSB300N adapter and installed the software on the cd, did the "new hardware" setup and then restarted my computer. I can only connect locally and can not get on the internet!
  • rs9052001 Dec 25, 2008
    my os IS windows vista, and the gateway is an WAG160N thanks for help me
How do I uninstall Linksys wusb300N adapter drivers without the software? The drivers are conflicting with my new N-PCI adapter. Linksys says I need to remove the drivers from my registry? Need help on...
Assuming you are using mirosoft windows, open the control, open "add or Remove Programs" select the linksys software, and click on remove. Then restart the computer.
Aug 18, 2010 | Linksys WUSB300N Wireless Adapter
The driver for my wusb300n was erased somehow and now i cant get on the internet to download a new one. Have any advise?
How did you post this question? If on someon else computer, download the driver on it to a usb drive and use that to install on your machine.
Oct 04, 2009 | Linksys WUSB300N Wireless Adapter
WUSB300N
This would most likely happen if your router is not configured to connect to the modem correctly. You said that you can connect to the router locally that means there is already a connection. The problem would be the routers configuration to the internet.
Jul 15, 2008 | Linksys WUSB300N Wireless Adapter
Linksys WUSB300N, cannot install driver
are you followin THESE instructions?
have you uninstalled the software that came with card?
With the card installed, go to device manager and expand the Universal Serial Bus Controllers tree and see if there are any ? or ! devices listed there
Also check under the network adaptors tree for same thing.
If there are any devices with either ! or ? highlight them and in the menu across the top select "action" and uninstall.
Do you hear the "ding" that usually occurs whemn a USB device is plugged in? if not this may indicate a connection issue
Try all USB ports on PC. Perhaps there is either a bad USB port or the connection is not good. Try connecting card via a USB extention cable (male to female) as it is possible that the shape of the card or the PC case means that the USB is not incerting far enough for good connection.
please post back results so I may assist further if required
Jul 08, 2008 | Linksys WUSB300N Wireless Adapter
Installation software lost where can I get onther coppy.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859916411&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1641140888B34&displaypage=download
make sure you download the correct version as described on the page.
Good luck !
May 15, 2008 | Linksys WUSB300N Wireless Adapter
Linksys Wireless-N USB Network Adapter WUSB300N Drivers
Hello, Click start, right click my computer, click manage. From there click device manager. This will list all installed devices including sound. Right click sound device and Click Update driver. Follow instructions. Reboot computer. If this doesn't work, get manufacture and part numbers off sound card. Go to manufacture web site and do a search for card number and download driver. Hope this helps
Mar 23, 2008 | Computers & Internet
Help needed with WUSB300N ?
I think your problem is CD. Change it or make download the last driver and try install. I think this solved your problem.
Dec 27, 2007 | Linksys WUSB300N Wireless Adapter
Linksys WUSB300N Wireless Adapter Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
