I connected both the legacey power and the sata power to the raptor WD 1500 and now it wont work is the any fix for this?
  • Alan Noor
    Alan Noor Jul 15, 2008
    thank you for your prompt reply is there any chance of actually recovering any data if I take it to a recovery specialist or is it simply gone?
  • 304 Answers
Cooked it, Sorry
Posted on Jul 15, 2008
  • George Kohler
    George Kohler Jul 15, 2008
    The data could be recovered by specialists though very costly
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
Hi There I am trying to locate the raptor 3.5"
Here's your solution, I had the same problem. Purchase Thermaltake Black Widow PC Gaming Hard Drive eSata + USB Docking Station (part number: ST0005U). I got mine at Best Buy for $55, but I'm sure you can find it online for much less. Good luck - trust me this works..... oh and by the way, dont buy a SATA-to-USB cable because your USB port on your PC does not provide enough power to the hard drive and you won't be able to access your drive.
Apr 13, 2011 | RPM 20PK 150GB RAPTOR SATA 10000 16MB...
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
Sata/bios problem???
Each non-SATA drive (CD or DVD or disk-drive) will have a small grid of pins, usually 3-by-2 or 4-by-2.
Look very closely, for labels: MA(ster), SL(ave), C(able)S(elect) for each pair of pins.
You allowed to have a maximum of *TWO* drives as "master",
but you probably have *THREE*.
Move the small "jumper" on each drive to the 'CS' position.
Then, the proper "master/slave" relationship on each IDE channel will be established.
Make sure your "boot" drive is connected to the "end" (not the "middle") connector on the "IDE1" (not "IDE2") channel.
Nov 06, 2009 | Computers & Internet
WD Sata drive was working perfectly then during the night
As you hear a tickling sound, I am pretty sure the HDD has gone faulty. Only way to see whether you can recover the data by your self is to fix the HDD into a external SATA enclosure and see whether it works and detected by the PC.
Otherwise the only option is to go to data recovery specialists who are normally very expensive.
It is worth contacting a local computer shop first.
All the best!
Jul 28, 2009 | Western Digital Raptor® WD1500ADFD 150 GB...
Raptor X seen on BIOS, but not on bootup
To speak Microsoft Window Customer Support representative dial +1 (800) 204-4427 (U.S.) 6 Am to 6 Am, (24*7 hours) Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our Microsoft technical support team 1-800- 204-4427, which is especially open round-the-clock for online assistance.
Our highly trained and experienced technicians have deep knowledge in fixing different types of all type Windows technical problems and have extremely high success rate in troubleshooting. To use our reliable Vista tech support services, please call our toll-free Tech Support Number at +1-800-204-4427.
Apr 26, 2017 | Western Digital Raptor X (WD1500AHFD) 150...
My new WD SATA hard drive does not have a 4-pin connector
Hi nas2,
You can purchas a SATA power cord addapter that can assist you. The cord is called SATA Serial ATA Power Cable. Unfortunetly, Best Buy™ does not carry these cables. You can however google the cord and order it online for cheap.
Sincerely,
Agent Xiong
Apr 28, 2008 | Computers & Internet
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Installing windows xp with 2 new sata wd 150g 10k 16m raptors to NO avail...
I guess you are trying to install Windows XP in RAID 0 configuration. If so, you need to do several steps:
1. Configure the bios to work as RAID 0
2. Download the RAID driver from the mobo vendor site, copy it onto a floppy disk and have it ready for when Windows asks for it.
See this link for detailed example http://www.duxcw.com/digest/Howto/mb/abit/kx7-333/raid1.htm
In SATA there is no master/slave configuration, so there is no need for jumpers.
I hope this answers your question.
Dec 26, 2007 | Western Digital (WD1500ADFD) 150 GB Hard...
Trying to install windows xp on SATA hdd wd raptor 74 g , i can see it in bios  but can`t install windows on it, i boot the cd with data lifeguard tool from western digital but nothing....need help
you need to put the sata drivers onto a floppy disk and when it asks during the xp setup do you want to install any 3rd party drivers say yes and load the drivers from the floppy. The sata drivers with the floppy generator should be on the drivers cd you recieved.
Oct 25, 2007 | ASUS S-presso Standard S1-P112...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
