Vulcan qasar gas wall heater. Pilot alight, but will not "fire up". Have performed the reset procedures as detailed on the heater, including complete shut down and relight of pilot (after audible click), but still no fire up.
  • Anonymous Aug 11, 2008
    Same problem with my Vulcan Quasar 40, any help would be great.
If your hearter is an electronic model the solenoid has almost certainly failed.
Posted on Aug 18, 2008
My wall mount propane heater sputters and won't fire up when I turn the knob to on
this quote is taken from site below under Problem Identification.
If the burner sputters on ignition or takes more time to ignite, there is definitely a blockage of the pilot orifice by dirt and dust. Set the pilot at a higher level and clean the orifice along with the burner ports.
Read more at Buzzle: http://www.buzzle.com/articles/how-to-repair-a-gas-furnace.html
Jan 09, 2015 | Heating & Cooling
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Vulcan climate control gas heater starts uo and does not stay alight after several attempts controls show reset mode have tried switching on and off does not work
There is a troubleshooting (problem solver) guide in the manual... you can see it here.....its the last page.
http://www.bonaire.com.au/lib/pdf/owners/mf228.pdf
If everything there chacks out then look for the thermocouple. I looked around and did not see one for the Vulcan heater. I would call then directly to find a dealer and a part number fo it.
Heatman101
Mar 09, 2010 | Heating & Cooling
Error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
May 26, 2009 | Heating & Cooling
Heating & Cooling Logo
778 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
