Question about Philips Magnavox MWR10D6 DVD Recorder
Problem the tray thing you put a dvd on is stuck like...it will not go all the way back in..its like something is keeping it from going back in
    Problem Solver:
  • 5 Answers
ALWAYS USE BUTTON TO GET TRAY TO GO BACK IN OR COME OUT IF YOU DO IT WITH YOU HANDS, IT WILL BURN YOUR MOTOR UP.
Posted on Aug 20, 2008
    Sergeant:
    Champion:
  • 258 Answers
Probably there is a disk up in the tray. if you moved it while a dvd was in the unit or tried to load one disk on top of another. [I've done it.] you may need to take the top panel off, bit it's not that hard. then removing the other disk will be easy.
Another possibility is the motor or gears are bad, the Kid put his toy in there, etc.
Posted on Aug 19, 2008
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
Dvd does not eject when open/close button activated?
Hello sir, hi!, the dvd tray is controlled by a single motor connected to a shaft/pulley where a belt is spun to roll a series of mesh gear to move the tray forward... well something like that, usually the problem is the belt, its wormed out, replacing this belt will tighten the pulley making the tray to eject. You need to disassemble the unit and get to the belt to replace it
Aug 31, 2010 | Philips Televison & Video
DVD tray will not go in
To verify there is nothing stuck in your drive, turn off your computer and try manually pushing the tray in GENTLY and feel if there is something blocking the tray moving. If there is nothing preventing the tray from moving manually push the tray in - start your computer and try it again. Use the eject function in windows explorer and try the retract button again. If teh button will not work try pushing the tray in manually again. Once the tray starts moving in it should automatically retract the rest of the way. If the unit will not retract on it's own by either method then the drive should be replaced.
Jul 29, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
When we put disc in tray keeps popping out and saying close tray.
There is a magnet inside the DVD drive that has dislodged and is now stuck to the top of the drive, causing the tray to keep popping out.
To fix this yourself, you're going to need to open your xbox, open the DVD drive, and glue that little magnet back in its place.
Follow this guide to do it.
Dec 14, 2009 | Microsoft Xbox 360 Console
SCREEN IS STUCK ON HELLO AND WILL NOT OPEN
On my DVD player, the cover on the disk tray was setting too high. I removed the cover, cleaned the glue off and reset it. This time it was flush with the tray. It now opens and closes just fine.
Another possible solution is to unplug and replug-in player. You still may have to do this after using my first solution.
Note: My DVD player also starts showing "hello"
Note: This solution was also listed under
"My DVD Wont Open" (sic)
Aug 14, 2009 | Memorex MVD2050-BLK DVD Player
DVD disc tray will not open
Without knowing the model for the unit, it makes it a little difficult to troubleshoot, but usually the easiest way to get one of these to open up is to try resetting them. This is done on MOST DVD players by unplugging them for about 30 seconds while you hold the power button down to discharge any power that might be held in the unit, then plugging the unit back in and trying to eject it again. Keep in mind, that if the unit was moved (or even if something caused the unit to shift, like a person jumping near it) then the problem could be the dvd has become dislodged from the tray. Many dvd players will have a small hole on the front (usually below the tray) where if you insert a paper clip in about a half inch, will eject the tray part way, and then you can gently pull it out the rest of the way (making sure you do not keep pulling if you feel resistence as the dvd might have skipped out of the tray track). IF worse comes to worse and you don't have a warrenty on the unit, many dvd players can be opened by removing 1-2 screws from the left and right sides, and possibly 1-4 screws from the back of the unit (look around the edges, the screws near the ports on the back usually holds those ports in place and do not need to be removed to take the case off). Once the screws are removed you would pull back and up on the case to open the dvd player. Keep in mind, this voids a MFG warranty. Once the case is off you should be able to see the dvd and remove it unless you have a cheap dvd player which has an enclosed drive. Remove the dvd and with the case still off, plug the power in (DO NOT TOUCH ANYTHING INSIDE WHILE THE POWER IS PLUGGED IN) and try hitting the eject button on the front. IF it ejects now, you should be good to go, just put the case back on. IF it doesn't eject, then your motor is probably bad (or something is blocking the track) and it is usually safer/easier at this point to just go buy a new dvd drive.
Jul 31, 2009 | Toshiba DVR3 DVD Recorder/VCR
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
Stuck dvd
I don't know the unit your talking about but I DO know that 1.) sometimes the DVD was put in crooked and get's jammed. Push the eject **** and push IN on the DVD door... it might staighten things out.
Don't put a screwdriver in there and try to wedge it out.... you could do a lot of damage.
Last thought - and ONLY if your comfortable doing this - is take the top off (usually two screews on each side, and take a look. You may see something. But DON'T DO THIS if tinkering is foreign to you. You might get a shock.
If this is an old DVD player, junk it or make an attemt, and if the attemt fails junk it. Let me know how you make out.
Mar 13, 2008 | Televison & Video
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Disk tray stuck.
My CD ROM try needs to be tightened, can you help me?
Jan 10, 2007 | GE 5803P Multi-disc DVD Player
Philips Magnavox MWR10D6 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
