Question about Kenwood Audio Players & Recorders
My subwoofer is buzzing - Kenwood Audio Players & Recorders
  • 1,512 Answers
Hi, bigandwhite2
Just need a little more information on your problem.
  1. is it mains hum you are hearing.
  2. is it there when you unplug the signal feed into the sub
  3. do you hear it at all volume levels
If you could kindly get back to me with some more info, we can diagnose the problem.
regards'
robotek
Posted on Jul 15, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
What is the buzzing in my subwoofer?
It has being a long, long time since I've work with a subwoofer.
Check to see if it's making ground inside the subwoofer. Not sure if this will fix it, but it works in mine.
Dec 19, 2015 | Audio Players & Recorders
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
electronics.howstuffworks.com/how-to-stop-subwoofer-hum.htm
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
I have a constant buzz tone coming from my subwoofer. I checked power connection, fuse and volume/crossover settings and nothing makes the tone go away. is there anything else I can do? Is it repairable?
Hello,if your subwoofer cable has gone bad this will introduce a hum(buzz) into your audio.I suggest replacing the subwoofer cable, a standard rca cable will do,and see if the audio cleans up.
Sep 11, 2010 | Snell PS.10mk2 Speaker
PS8 Subwoofer started buzzing non-stop
with nothing connected and the sub turned on....Most subs buzz when the circuitry starts to fatigue. The last time I heard this ..the repair ended up being one of the two fat capacitors inside the sub. I have a means of testing this,,you may not. I am a repair shop with a bit of experience in component level board repair.
May 06, 2010 | Proficient S12 Subwoofer
Loud buzzing when switched on. Not connected to receiver. Should I open up the back of the subwoofer? Bad fuse? Thanks, RC
If there is a buzz and the lights are on its prabably not the fuse. If the buzz is being heard from the speaker than the speaker is okay. the amp may be blown
Jan 17, 2010 | Audio Players & Recorders
Subwoofer stopped working
You have a bad connection to the subwoofer.
Mar 07, 2009 | Monitor Audio Radius R360 Subwoofer
Kef Kit 100 Subwoofer Buzz
i got the same buzz problem
Oct 26, 2007 | KEF Audio KIT100 System
177 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
