Question about Nokia N73 Cellular Phone
Lifeblog i can't open my lifeblog of my phone(N73)
  • Anonymous Jul 17, 2008
    ive got the same problem!
    Problem Solver:
  • 6 Answers
Weird problem ...well i guess if its serious then do hard reset *#7370# everything will go back to normal ... but phone memory will be erased completely.
Posted on Jul 24, 2008
I hv Nokia N73, it is shwoing "phone memory full, delete some data", i hv check it through "file explorar" there is one file in C://data/lifeblog/lifeblog.db, the size of this file is...
u should connect ur phone to a pc and get into the phones memory. just right click the files go to the properties and uncheck the protected mode. After thant u can also delete it from ur pc. Hope it help to solve ur problem.
Thank You.
May 11, 2011 | Nokia N73 Cellular Phone
Nokia N81 Phone memory problems.
To start, please note 34KB isn't much space at all. That phone has a minimum of 12 megabytes and a maximum of 8 gigabtyes depending on when you got your phone.
But just for size comparison, 34 kilobytes = 0.033203125 megabytes so you have plenty of space, those kilobytes mean nothing.
I don't personally own a Nokia phone, but from what I hear, all of their phones have software on them called Lifeblog, it stores all of your photos taken, and all of the calls you have made on your phone and arranges them in a time line, this ends up taking up a lot of space and is a cause for many of the memory related problems.
Possible Solutions:
First:
Backup anything you want to keep with Nokia PC Suite
Then:
Reset your phone to factory default by either typing *#7370#
OR
Holding down 3 * green whilst switching it on.
Be wary when restoring any backup you have, being this will restore anything that your Lifeblog contains, reverting the problem.
And a final solution
Download "Y" browser here
Install it on your phone via your Nokia PC Suite.
Launch the YBrowser application (probably from new folder called DrJukka.com):
Locate the C: drive and open it:
Locate the Data folder:
Locate the Lifeblog folder:
Select Options, File and then Delete
Once the folder is deleted launch Lifeblog and select Update Timeline.
Hope one if not all of these helped =)
Jul 13, 2009 | Nokia N73 Cellular Phone
Repeated display 'memory full delete some data' when the phone memory is empty,most probably a virus, how to deal with it?
I don't personally own a Nokia phone, but from what I hear, all of their phones have software on them called Lifeblog, it stores all of your photos taken, and all of the calls you have made on your phone and arranges them in a time line, this ends up taking up a lot of space.
Possible Solutions:
First:
Then:
OR
My nokia n73 shows phone memory is full but nothing is in it
hie dear,
u need to refresh or soft format ur phone memory.
for that pres *#7780# and then the phone code (12345 by default)
it will not harm any of ur messages or the contact saved on ur phone, it will just refresh the memory.
bunty
May 22, 2009 | Nokia N73 Music Edition Smartphone
How to delete some data in my nokia n73?
Try to delete songs or setups that you might have kept in the phone memory (c:) drive of your phone !
and make sure no application is running in background before opening LifeBlog.
For better viewing of the files kept in the phone memory use X-PLORER software !
It rockx.
Thanks
Apr 09, 2009 | Nokia N73 Cellular Phone
My N73 too slow
I have my N73ME for 1.5 years, now.
I had same problems. I've tried with log deleting, memory card removing, log setting to 1day - nothing.
Then, I dig through my N73 and I've found LifeBlog application which is incredibly filled with all my messages, pictures and stuff from the 1st day I bought it. Deleting of 5000 records went all night long.
One thing is also good. Before this I did firmware upgrade and now I don't have that annoying bug of being unable to call my contacts from time to time (which requires phone restart to).
may the force be with you!
Benneton
Jan 03, 2009 | Nokia N73 Cellular Phone
N73 phone memory problem
Hello friends....
u dun need to panic, here's a very simple solution!
The phone memory drops basically coz of LIFEBLOG DATABASE file. You need to have some Explorer Software to access this file. Either install X-plorer v1.22 or Y-explorer etc etc.
Then follow these steps:
1. Go to C:\Data\Lifeblog\Database
2. You will find a file lifeblog.db, it is because of this file whose size varies. Usually it stays around 1 mb but sometimes it goes upto 20mb + driving out whole of the Phone Memory.
3. Try deleting this file.
4. In case it gives a message that file cannot be deleted coz it is in use by some application, then go back to folder.
5. Rename the "DATABASE" folder to any other name. Now you will be able to delete "lifeblog.db" without any error msg. After deleting that, rename the folder back to DATABASE.
Here you go....ur problem is solved!
I wud like to have ur feedbacks!
Thanks
Harchetan Aneja
Mechanical Engineer
Jan 24, 2008 | Nokia N73 Cellular Phone
Nokia N73: Failure to copy photos from phone to PC
i would suggest you use the Nokia PC Suite. the CD is included in the package or download it in this link http://europe.nokia.com/A4144905 . It will create a Phone Browser as part of your Windows Explorer.
Please Rate Thanks
Jan 07, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
125 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
