Question about Dryers
I have an older 70 series dryer. I was working fine and then my last load of clothes didn't dry. The dryer did not get hot.
  • selinagosset Jul 16, 2008
    this is a gas dryer. Is there still a fuse on this as well and if so where. I took the back cover off last night and cleaned out all the lint and dust and didn't notice a fuse.
  • 525 Answers
Based on your complaint; "I have an older 70 series dryer. I was working fine and then my last load of clothes didn't dry. The dryer did not get hot,"
Temperature Switch:
Make sure a positive heat selection has been made. Then check these:
This information is for an electric, generic model dryer only!
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 15, 2008
  • David Emmel
    David Emmel Jul 16, 2008
    I apologize for causing you a delay, but that is why we need a make and model, because they are all different.
    If your dryer was manufactured in the 70's, (fuses were not used in the 70's) or is a 70 series, here are some things to look at for a generic gas dryer.
    Temperature switch:
    Make sure you have a positive heat selection!
    Igniter
    Gas valve coils
    Igniter
    Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
    The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
    Gas valve coils
    Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
    Most gas dryers are serviced from the front. Below is an exploded view diagram showing how to disassemble your dryer.
    You will have to enter your model number in the search box to find your particular diagram. Tip: Gas valve solenoids(coils) are the #1 item for failure.
    http://www.repairclinic.com/0047_8.asp
    Below is a link to a parts digram that shows older style coils.
    http://www.repairclinic.com/SmartSearch/...
    In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
    Thank you,
    Dave E. (Illeagle)
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Doesn't move hot air to the outside
Clear obstruction to hose outlet.
Vitally
Jun 02, 2009 | Dryers
Won't dry clothes
Try running the dryer with the vent pipe unplugged. There should be a lot of hot air coming out, if not the insides need to be cleaned. If it really moves air, and dries a load ok unhooked, your vent is clogged. Clean it if you can. If you can't, look into a lint trap that will work for your situation, some have a water trap, some are good filters, etc. If the air is not hot, some of the electric element may be bad. If it's gas, it could need a tune up and cleaning inside.
Apr 24, 2009 | Kenmore Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Feb 28, 2008 | Dryers
Dryers Logo
154 people viewed this question
Top Dryers Experts
