Question about Kenwood Car Audio & Video
Kac-819 kenwood amp 450 watts won't turn on problem with the remote the light on the amp blinks blue once then thats it no red light on no green light nothing ran a jumper from the 12 volt side to the remote samething blue light blinks once than thats it don't know what to do.
Draco
SOURCE: when i turn my radio up all the way my speakers cut out and then come back on
i soundds like its too powerfull for them beouse some new speakers now have a shut off if they are ready to go out or blow to make sure you dont damage them
Posted on Jan 15, 2007
  • 631 Answers
SOURCE: kenwood kac-7202 amp
150/ch into 4 ohms
230/ch into 2 ohms
Spec Sheet
Posted on Jan 11, 2008
  • 7 Answers
SOURCE: my kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Posted on Nov 02, 2008
LVT7857
  • 116 Answers
SOURCE: Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • 11 Answers
SOURCE: My PG Xenon 600 watt amp will not power my subwoofers
hello it sounds like your problem may be in the remote/power wire that goes from the back of your radio deck to the amplifier. the amp should have a wire connection that says remote,p.con, or antenna. and its usually the smallest wire connector located by the power and ground wire. this wire goes to the solid blue wire coming out of the deck. you can conect the wires together any way you want. i usualy shave off a little pice of the wire cover and wrap the wire coming from the amp around the bare wire then cover it in electical tape or cut the blue wire from the deck at a fit length and use a wire nut and put the two cut ends in and also the wire coming from the amp. also make sure the amplifire dose not have power to it just to be safe. wouldent want to fry anything.
There is also the left and right wires(ususaly red and white) that go on the back of the deck to the amp.
also chek the volume on the amplifire
Posted on Apr 13, 2009
The amp.
check power fuse make sure it's not blown and gettin proper 12 volts if all connections are properly fixed maybe get it checked out
Jun 06, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Not powering up
is the REM wire from the unit hooked up to the amp?
Aug 11, 2009 | Kenwood KAC-8402 Car Audio Amplifier
On a kac-x650d does the power light stay on or flash
Hello mpredday,
The Kenwood Excelon KAC-X650D power light is ON during normal operation. It blinks blue to indicate BMS selection, yellow for low voltage, purple for DC voltage on the outputs, red for overheating, and green for a shorted or grounded speaker wire.
Hope this helps.
Jul 29, 2009 | Kenwood Car Audio & Video
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Cant get but one side to work
This amp (kenwood  819)  was designed for use with a sub-woofer, hence the single chanel. It will however power up 4 speakers in mono, and if they are capable of handling the amps.while robbing you of the benefits of stereo as well as left, right and fade control.Good luck...
If you still want it connected. You should purchase an amp installation kit, and review the topics and videos at this web site. www.installdr.com
Good luck...
Feb 24, 2009 | Kenwood KAC-819 Car Audio Amplifier
Larry T
Winona Lake, IN
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
KAC-X520 kenwood 1000w amp
a red light indicates you got no power check your wiring you may not have a good ground, you need the green light to come on
Oct 09, 2008 | Kenwood KAC-X520 Car Audio Amplifier
Car Audio & Video Logo
109 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
