I just purchased a new Pixma MP530 printer. Installed the print head, ink, alligned print head, loaded the software, but am unable to get my Mac to recognize the printer. I have a Mac OS 10.5 and have used Pixma ip4200 for two years before it died. I cannot get the new 530 to respond and cannot figure out how to get my Mac to recognize the new 530. When I try to print all I get is the ip4200 which is no longer online. I even downloaded Print driver ver. 4.8.3 but that did no good. I'm frustrated, how can I get this new printer to respond????????????
  • 2,794 Answers
Do you have another USB cable to use?
Posted on Jul 15, 2008
  • Tim Babcock
    Tim Babcock Jul 15, 2008
    Do you have another computer to plug it into to see if its working.
    Sometimes the USB cable do fail. That's why I gave you that suggestion.
    Otherwise you might have to take into the shop to see why it isn't connecting.
    I would appreciate it if you would change your rating.
I forgot how to change the ink cartridge on my printer i dont rember where it is please help
If you go to the below link -
Canon MP530 manual
and look at pages 44 - 46 it shows you how to change the ink cartridges. Just bear in mind the page takes a while to load as its a 4mb pdf so it will just stay black for a while until it downloads.
Thx, if this solution helps please rate :)
Feb 03, 2011 | Canon PIXMA® MP530 All-In-One Printer
My Canon Prixma 530 has the "Memory in Use" light on and will not print. There is nothing in the print cache (no jobs pending). How do I get the printer to print (all other functions still work).
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Appears to be printing but nothing on page
Let me lay down the possiable reason:
Blocked nozzel
bad print head
dirty print head
dried ink in cart.
OK I laid down some issues aboce invistgate them all and let me know right away. You can purchase a print head for this also you cna purchase print head cleaner,
did you run a allignment?
please od leave some feedback and ratings for your free answer today.
May 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Mp530 edible ink
You need to clean the print head manually. Remove tanks from print head, then remove print head. Find a small tray you can put hot water in to the depth of a quarter inch / 6 mm. Soak bottom of print head. Do not touch or get wet the electrical contacts. Next while holding print head in left hand carefully pour a small amount of hot water in the each ink tank well in the print head. Now dab the bottom of the print head where the jets are with a paper towel. Keep dabbing till you get equal size spots of all the colours. Best to wear plastic gloves doing this. Best to use battery water (de-ionized) but if you don't get scale in your electric jug your tap water is fine.
Sep 18, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Installed all new ink cartridges and now poor printing results
Dear louis,
You have done right thing by cleaning the print head. If the print head still clogged after repeatedly cleaning, It seems that the print head need to be replace with new one. Make it sure by printing nozzle check pattern. Is it good or not?.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Getting error 681 "more thn one magenta tank instaleld" on MP530
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ink cartridge red light
need original canon ink cartridge not generic
Jan 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
70 people viewed this question
k24674
jasbo
jasbo
