Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whrilpool washing machine will not fill
I turn the dial to start the washing cycle and the agitator starts with no water in the machine. If I turn the dial to another cycle ie:rinse or spin... it does nothing.
  • 1 more comment
  • jedi7908 Jul 18, 2008
  • bigblueswami Sep 27, 2008
    had the same problem... it was the screens on my washer. We're on well water so there was plenty of debris coming through the lines. Thanks for the fix!
  • J. Fernandez Oct 24, 2008
    I have the same issue with the same model washer. I have cleaned both screens and water runs into a bucket when not connected. Is it safe to assume that the problem is the water solenoid??
    Sniper:
  • 68 Answers
May I first suggest that you turn both the hot and cold water off to your washer and check the screens installed in the back of the machine. A lot of times dirt and debris can clog the supply lines. After you check the supply lines, turn the water on with the hoses in a bucket. This will make sure that you are getting water to the machine. Replace the lines, and turn the supplies back on. If you are still not getting any water, you are looking at a bad water solenoid.
Posted on Jul 28, 2008
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
No water coming into washer, but washer starts agitating at start
Your water level switch is defective.  It is generally located below the tub.  It is jammed closed and the machine thinks it has water in it when it does not.
Nov 20, 2008 | Washing Machines
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
