Question about Brother MFC-8860DN Printer
Replace Fuser Reset
Replace Fuser appeared on the LCD, and as it was over 100,000 copies and the fuser roller did appear rather past its use by date, we replaced the fuser unit. Its now working great. How does one reset and get rid of the replace fuser error message? please
Im sure its a code in the Maintenance menu, but Im not sure just which one.
  • bitbit125 Mar 30, 2009
    I just replaced the PF Kit 1 and I followed instructions to remove "Replace PF Kit 1" on my printer screen. As soon as I was done "Replace fuser" popped up on the screen. I need to remove it
  • Jonae Jan 18, 2010
    my brother 8860 DN wont exit maintenance mode. I turn it off an on, i tri the 99 (i hope i am doing it corectly) but nothing. Please help.
For the MFC 8860, I turned off the printer. I help down menu. I turned on the computer. It entered Maintenance mode. I typed in 88 (Parts Replacement.) I scrolled to the fuser, clicked ok. Then, I turned off the printer. When I turned the printer on, it said that I needed to replace my laser. I then turned the printer off, help down menu, turned the printer on, typed in 88 at the maintenance menu (parts replacement), scrolled down to laser, and hit ok. I then turned the printer on and off, and poof, now it works. I find it quite unscrupulous that I had a replace PF Kit1, replace Fuser, and replace laser messages all within one hour...
Posted on Dec 15, 2008
Enter Maintenace menu by pressing
Menu,*,2,8,6,4
8,8 for parts life
scroll down to fuser
hit start for yes
9,9 to exit
Posted on Aug 29, 2008
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
My laserjet 1020 has a paper jam output message, i followed the instruction that appeared on the screen, but still, the message appear when i tried to print, there is also a red blinking light
Try to press the reset button on your printer if did not works just try to download the reseter of your printer in HP Laserjet 1020 at the HP website. Because your printer have a lifespan printing; example if your printer have a 100,000 copies to be print so you have aloud to print not more than 100,000 copies. That's why need to reset your printer using the reseter program by HP.
May 26, 2010 | HP LaserJet 1020 Printer
When should the fuser and rollers be replaced on the Dell 3110cn?
Fuser life is 100,000 pages.
Pickup and transport rollers - replace when defective - no 'fixed' life, but if you are replacing fuser, it's worth changing the pickup and transport rollers at the same time.
Note Transfer belt also has a 100,000 page life.
Mar 05, 2010 | Dell 3110cn Laser Printer
Ghostly effect
If drum is a genuine Brother, then open the rear door and look at the fuser rollers, if you see toner or partial images on the rollers you need a new fuser, if the fuser is clean, look at the drum surface and if you see parts of last print then the drum is bad. In reports, print the user options list it will give the total print count. The fuser is worn out around 80 to 100,000 prints.
Jan 11, 2010 | Brother MFC-8460N All-In-One Printer
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Dec 02, 2009 | Sharp AR-507 Copier
Two images appear on copies in both text and
Hello sir; It seems like drum blade worm out need to replace also possible fuser roller worm out too ,my suggestion is replace both of them.
Nov 06, 2009 | Lanier 1205 Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
When photocopying, a copy is made however the text also appears faintly in the background. (Model no: Xerox WorkCentre XD120F)
That would be either a bad heat roll or pressure roll.
In the area where the copy exits, the hot fuser area, eithet the heat roller, TOP roll or pressure roller, Bottom red roller are worn.
Easiest thing would be to replace the fuser.
Contact this parts reseller.
https://www.partsdrop.com/store/
Apr 21, 2008 | Office Equipment & Supplies
Paper Jams
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
Brother MFC-8860DN Printer Logo
6,752 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
