Question about Sony DAV-SA30 System
Dvd player is in region 3 need multi region for model philips hts3548w/98
I need to chenge my dvd player to multi region
  • msgrenada Apr 16, 2009
    Mines a LG DVD 5063 and I want to make it mulit region
1.open tray with empty CD
2. press stop for 2 seconds
3. press 734466
4. on the screen region will appear press 0 for all regions
5. press ok to close then after open and insert your DVD.
Posted on Oct 16, 2009
    Champion:
  • 224 Answers
Brand and model?
Posted on Jul 15, 2008
  • Rod
    Rod Jul 15, 2008
    I have found some info on Sanyo players for you,might be of some use?
    Steps to unlock Sanyo DVD Player Region Code Restriction
    Sanyo DWM-370, Sanyo DWM-380, Sanyo DVW-7000
    1. With no disc inside the DVD player, turn on the power of DVD player by using remote control.
    2. Use the remote control again, and press 11233543254346.
    3. Power off the DVD player with remote control.
    4. Power on the DVD player again with remote control, and you should be able to play DVD disc from any region.
    Sanyo DVD-SX25, Sanyo DVD SX20 Slim DVD Player
    1. Turn main power ON.
    2. Confirm that “NO-DISK” was displayed on the display panel.
    3. Press the ‘Display’ control key on the remote control. Select ‘Video’.
    4. Input the password “1,3,5,7′ using the remote control.
    5. The confirmation screen for the version of the firmware should display.
    6. Change the region code (between 0-6) with the “up” or “down” key of
      remote control, with “0′ is region-free, and “2′ is standard for Europe)
    7. Finally, press the ‘Display’ control key on the remote control to confirm choice.
    Sanyo HV-DX3E DVD Player & Video Cassette Recorder, Sanyo HV-DX300A
    1. Switch the HV-DX3 to DVD mode using the “Select” button.
    2. Next, press the Tray “Open/Close” button.
    3. Using the remote control, press the following numbers one after the
      other, 0, 5, 2, 0, continue by pressing the Up, Down, Left and Right
      navigational buttons in that order. If you have pressed the remote
      control buttons in the correct order, the Region Changed Menu Screen
      will be seen on your display.
    4. Using the remote control press number 0 to change the player to Multi-Region.
    5. Finally press the “Open/Close” button to close the disc tray, this action will memorize and save the changes made.
    Sanyo DVR-V100E DVD Recorder/VCR Combination, Sanyo HVRDX610
    1. Remove DVD or video from the player.
    2. Press the ‘Set-up’ button on the remote control.
    3. Select the ‘System Info’ mode from the on-screen menu.
    4. Using the remote control 10-key type in ‘1101′
    5. ‘Region code’ should appear as an option on the ‘System Info’ menu.
      Initially the region code will be set to 2. Press ‘0′ on your remote
      control using the 10-keys to set to multi-region.
    6. Press ‘OK/Enter’ on the remote control.
    7. Finish by pressing the ‘Set-up’ button once more.
    Sanyo DVR-S120 DVD+R/RW Slim Recorder
    1. Open the disc tray and then close it again (confirm that ‘No disc’ is displayed on front LCD panel display).
    2. Select the ‘System’ key on the remote control.
    3. Push the ‘Play’ button on the remote control.
    4. Type in ‘159′ using the 10-key on the remote control (letters should disappear on front LCD panel display).
    5. Type in ‘064135124255′ using the 10-key on the remote control.
    6. Finish by pressing the ‘Play’ button once more.
    Sanyo DWM-450
    1. Power on the DVD player.
    2. Eject the DVD tray by using remote controller.
    3. Press 5, 7, 9, 2 in sequence.
    4. Select 0 to set the DVD player to multiregion.
    5. Close the tray.
    Sanyo DVW-5000
    1. Remove all disks from DVD player.
    2. Turn off DVD.
    3. Press “Power” in the remote control.
    4. Wait until the NO DISC message appears in the screen.
    5. Press PAUSE.
    6. Press the following numbers 314159 in sequence.
    7. The message CODE 1 (or whatever your default region code is) will appear.
    8. Press the region code that you wish. Press 0 to read discs for any region.
    9. Press PAUSE again.
    10. In the remote control press POWER to turn it off.
    11. After this procedure, turn on the DVD and insert a DVD from any region.
    Sanyo DVD-SL33
    1. Switch on the DVD Player.
    2. Enter the number 89239990 through the remote control.
    3. A message UPDATED will display on the display panel of the DVD.
      Once you get this message, the DVD has been converted to multi-region.
    Sanyo DVD-DX501, Sanyo DVD-DX506, Sanyo DVD-DX510 *Original intend for Daewoo DV-700S
    1. Turn on the player and open the drive tray.
    2. Enter 8286* (replace * with number of the region you want to switch to, 0 for region-free).
    3. A message should appear on the screen saying “Change to region *” with the * being the region entered in step 2.
    4. Close the tray.
    Sanyo DVD-7201, Sanyo DVD-1500A, Sanyo DVD-1550A, Sanyo DVD-5100, Sanyo DVD-6040, Sanyo DVD-6070
    1. Press the Program button on your remote control.
    2. Press the Right Cursor button on your remote control.
    3. Press the Right Cursor button on your remote control.
    4. Press the Enter button on your remote control.
    5. Press the Play button on your remote controly.
    If the above step-by-step instructions don’t work, try to use the
    following cracked firmware method. Note: Use at own responsibility, as
    your DVD player may goes wrong.
    1. Download spookytooth-sanyo1500crack.zip.
    2. Extract the zip file to retrieve the following 3 files: Dummy.dat, Sanyo.dvd and Sanyo.prg.
    3. Burn these 3 files (only) to a data CD with volume label: 001017_1251.
    4. Then, turn on the DVD player.
    5. Put the CD into the disc tray, then close the tray.
    6. A “reading” message will appear at top right of TV and on the LCD
      display. The DVD player machine may appear to turn off strangely too.
    7. Wait for approximately 30 seconds, then the disc will eject automatically when it’s done.
    8. Remove the CD.
    9. Turn on the machine and you should be able to play DVDs from everywhere.
    Sanyo DRW-1000
    Note: This player only plays NTSC and the method to enable
    region-free playback is similar to Zenith XBR-411, GO-Video VR-4940 and
    Zenith XBR-413 unlock steps.
    1. With no disc loaded press SETUP.
    2. Navigate to the lock icon and press “0-0-0-0′. A window will appear saying “Congratulations Player(Loader) Region-free”.
    3. To activate, press ENTER.
    Sanyo HV-DX1E, Sanyo HV-DX2E, Sanyo DVW-7100
    Note: The unlock multiregion hack is same with LG DVD-5000, and also LG DVD-5063/5083/5095/5183/5253/6053.
    1. Download LG5000.zip.
    2. Unzip the zip file, a folder named RMTM0000 will be created, which contains a file named kpjc19_1.dvd.
    3. Burn the RMTM0000 folder to a data CD by using lower writing speed i.e. 24x.
    4. Switch on the DVD player with remote control.
    5. Insert the CD into DVD player and close the tray with remote control.
    6. On screen you will be promoted to “ENTER REGION CODE”.
    7. Press 0 for region free, and then press Enter.
    8. Turn off your DVD player with the remote control.
    9. You can now play all DVDs.
NEED TV CODES FOR PHILIPS TV. I HAVE A ONE FOR ALL MODEL URC-5741B00 REMOTE. NEED CODES FOR A PHILLIPS TV.
Here are the codes for your philips tv:
  • PHILIPS Codes: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
  • Apr 15, 2011 | One For All URC-3021 Remote Control
    Need to get my philips dvd player 3120 onto muliti
    Using the remote controller:
    Press [SETUP]
    Select Preference page
    Press [1] [3] [8] [9] [3] [1]
    Select region code using [UP] / [DOWN] buttons.
    Apr 25, 2009 | Philips Televison & Video
    Multi region code for philips hts 3090 dvd player
    With your set on and without disc in the tray:
    1. Press PLAY from your remote control
    2. Press the following button sequence: 1590 2379 390
    3. Press PLAY again
    This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
    I've done this to my 3090 and been using it like this for 3 years.
    Mar 08, 2009 | Philips Televison & Video
    Philips mini DVD PET702/75 multi region unlock code
    To check the software version and change
    region code of your DVD Portable
    1. Power ON the DVD player and open the DVD
    door
    2. Press the “SETUP” button on remote control,
    then select the “Preference MENU”
    3. Press the remote button in the sequence as
    9 -> 6 -> 5 -> 3
    4. The LCD display showed the existing region
    code. Press (navigation up) or
    (navigation down) repeatedly to select the
    number from 0 to 6.
    5. Refer below table for your region code setting
    moz-screenshot.jpgmoz-screenshot-1.jpgRegion
    1=USA
    2=Europe
    3=Asia Pacific
    4=Australia, New Zealand
    5=Russia, India
    6=China
    Select “0” setting = Region Free (confidential)
    Feb 28, 2009 | Philips Televison & Video
    ''WRONG REGION'' MESSAGE ON PHILIPS HOME THEATRE SYSTEM
    Ensure both TV & player are on , no disc in player
    on the remote press: disc menu, then open/close then stop
    enter the following numbers:
    7,3,4,4,6,6,0
    you should see region 0 in the bottom left hand corner
    the player should now play, if not and your in Australia ring Philips on
    1300 363 391
    good luck
    Terry
    Jan 11, 2009 | Philips HTS-6500/37 System
    Hack wanted to enable multi region
    1) Go to the Preference page in the Setup menu
    2) Press 1 3 8 9 3 1 on the keypad of the RC. I had to hold each number down for 2 or 3 seconds.
    3) Options will be available to be selected. Select 0 using up/down on remote.
    4) Player is now region free.
    Aug 31, 2008 | Televison & Video
    Philip PET 702/98 Poratable
    On remote push "Setup", use arrows to find out page "Preferences", enter 9653 and change region code to 0.
    Mar 31, 2008 | Philips PET702 Portable DVD Player
    Phillips Home Theatre System
    to play discs from different regions on HTS3548:
    Before you begin, ensure you have connected your DVD player to your TV and both have the power on. Once you have connected the TV, follow the instructions below.
    -- Open the disc tray
    -- On the remote control, press in sequence:
    Disc Menu
    Stop
    7 3 4 4 6 6 0
    OK
    -- Make sure Region 0 is showing on the TV.
    This should hopefully help!!!!
    Jan 02, 2008 | Sony DAV-SA30 System
    Sony DAV-SA30 System Logo
    1,384 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
