Yep, same thing happened to ours. It would reel the label tape through and sound as if it were printing but nothing would show up. We replaced the batteries and it works perfectly again.
Thank you....duh! :) Just needed new batteries. Works perfect again.
I have the same issue, tape is moving and sounds like it's printing, but it just rolls the empty tape,,, new batteries did not fix... any fixes?
I have the same issue. New batteries, new tape. Even prints like 2 letters and rolls enough tape for maybe 6 letters. Then exclamation points start flashing.
I have changed batteries, bought new cartridge and still no printing occurs. Label cowards but nothing appears
Below are the actions for our visitors to access the Musically Online solutions on their gadgets musically login Select the join tab as well as pick among the complying with settings to develop.
SOURCE: Faint Printing
TRY PUTTING NEW BATTERIES IN THE DEVICE AND THE LETTING WILL GET DARKER SO YOU CAN SEE IT
ROD
SOURCE: Dymo LetraTag 2000 hand held printer
This Unit does NOT take ink. That is one of it's "benefits." Since it uses heat transfer, im thinking it either needs new batteries, or it's heat device has been expended. This is a cheap little maker, so it isnt made to handle the abuse of an office: it's meant for a label from week to week. If you went on a label spree all over the house, you killed it. Hope this helps!
SOURCE: how do you print vertical labels?
Here is the link to your users manual, which will help explain other functions you may find useful.
http://global.dymo.com/enGB/Manuals/LetraTAG_QX50.html
Hope this helps...
Gods Bless.......
SOURCE: Does a DYMO Letratag QX50 have a replaceable ink
It is a thermal printer and thus does not use ink.
The most likely cause of poor print quality is low batteries. Replace your batteries or plug in the power adapter.
If this does not help check that the label cassette is in place correctly and that the print head is clean. You could also try a new label cassette.
SOURCE: I have a Dymo Letratag XR and it is only printing
change the batteries! there is no ink, this problem is nearly always flat batteries...
