My hard drive is not being recognized but its still getting power too it but its not showing up on the computer any where so i think there is something wrong with the usb port on the hard drive
  • mansellnatha Jul 15, 2008
    Thanks for trying but unfortunately it didn't work but I do appreciate the help
    President:
  • 778 Answers
Shut down computer, plug in USB hard drive, start computer, open "My Computer" and see if drive shows? If so, you may have to format it before using it.
Posted on Jul 15, 2008
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
My external hard drive wont show in my computer but it is recognizing it in disk manager
Hi, is the drive clicking, or making any noise?
are the lights on the drive blinking?
try the drive in another computer, if all fails i think you might need to go to your local PC Store
Mar 02, 2011 | Hitachi Computers & Internet
I got into my Coolmax external hard drive on my computer, via internet cable and router. I got into the hard dirve OK. I am trying to get another 2nd computer recognized on the hard drive. The Coolmax...
Indeed, it sounds like a sharing problem. But, based on your explanation, I'm not sure what your issue is as your terminology is not standardized.
Example: you said, "I am trying to get another 2nd computer recognized on the hard drive." What would be more accurate, is that you are trying to get the 2nd computer to recognize the 1st computer so you can access the 2nd computer's hard drive.
On the other hand, you said the hard drive uses a network interface, and you have it connected to the router. So does it have some kind of web based interface? No, if what I read about it says that it uses USB 2.0 and eSATA, which means it is directly connected to the 1st computer, and so it would have to be shared to the 2nd computer via the 1st computer.
I also note you don't specify any operating system, which is absolutely required. Because, for example: Windows 10 has sharing problems; I'm a professional, and I haven't bothered till they fix it.
You said: "I registered the ID and password", which does sound like you're using Windows to set up a share. But then you say, "Did Run //storage/person" which means nothing to me. As that's not any way to set up a share that I'm aware of. (Maybe I'll learn something ;-)) And then you say, "2nd computer's hard drive was not recognized" and that's confusing, because I thought you were trying to see the Coolmax which is on the 1st computer, right? Or is it on the 2nd computer. So it's really not clear what you're doing, or what you think you're trying to do. If you clear this up, I'd be happy to see what I could do to help.
How to set up File Sharing on Windows 10
Jul 04, 2017 | Coolmax HD-211-eSATA Hard Drive
My T-6330u no longer recognizes my hard drive I bought a new hard drive but the end result is the same is this something to do with the motherboard?
This can be from a number of things.
1rst, is the drive showing as disabled in your bios?
If not, with laptop powered off, then try unplugging the dc adapter and removing the battery. remove the hard drive. Let the computer sit for a few minutes.replace the battery but do not plug the dc jack back in. boot the computer without the hard drive and let it go to the point of failing boot with no hard drive.
Power off. hold down the power button and let it cycle power (goes on then off)
remove battery and replace hard drive. try to boot and see if this will allow your hard drive to recognize.
If this doesnt work then repost and can go from there
Feb 14, 2010 | Gateway T-6330U Notebook
My Hitachi SimpleTough external harddrive is not being recognized by my computer. It is plugged into the computer, so I do not think it is 'power source' issue. It is not listed in the tree to the left...
Hello
Does the computer make a sound, or recognize that there is a device plugged into your computer. If it does,does it give you the pop up that the device is not recognized?
If so, try plugging in the external into one of the back USB ports at the back of your computer case. Also shut down your computer unplug the power cable to the computer itself for 5 - 10 minutes. This worked for me.
If the computer recognize that there is a device plugged in, but just does not show in My computer, here is how you fix this.
If the HHD gets power and you can feel the drive spinning, you can try these steps and see if your problem is solved. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
If you cannot see any power light flickering or feel movement on the drive when you power it up, then there is a other problem. Hope this can help you.Feel free to leave a comment if this doesn't work so we can try something else.
Best regards
Andrea
Nov 11, 2009 | Computers & Internet
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
External Drive Recognized
is it possible for you to plug it into another PC?
to see if the problme is the HD or a drivers issue in your PC.
Jan 20, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Lacie 250 gb hard drive isn't recognized on computer
Controller got smoked when cable unplugged, take in if ya need the files off.
Nov 04, 2007 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
