Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Hifonics amp keeps blowing the main fuse
I have a Hifonics bxi 1206d amp and everytime i hook it up it blows the main fuse. I have tried it in both my truck and my friends and it does the same thing. I have checked and rechecked all the wiring to make sure there are no loose ends. How can I check the amp to see if there is a short in it?
  • hotracer_05 Aug 14, 2008
    i actually have a 100 fuse in there and its 4 gauge wire.
  • djaxe2210 Mar 11, 2009
    i have this same problem i have a 4 gauge wire my 60 aug fuse blew when i was playing it on a low volume, so now i a 100 aug fuse but now im getting engine feedback when i turn on the system. but now my hifonics amp has a protect light on ... what do i do ??
Make sure you have your negative in the ground input on the amp and the postive in the 12volt input.....if by accedient you mix the two everytime you replace the fuse it will bloooooooow
Posted on Sep 01, 2008
  • 4 Answers
Have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Posted on Aug 14, 2008
What do i do when its telling me that its protected.
Over current protection turns on when the amp draws more current than normal. It turns on so it doesn't catch on fire. Your amp has a fault, most likely in the output stages. These power transistors consume the most current and if they blow short then that will cause it to go into protection. If it is under warranty take it back, if not have someone in your area try to repair it. What load were you running anyway?
Dec 19, 2009 | Hifonics Brutus BXi 1206D Car Audio...
I have a HiFonics 1206D amp and it keeps blowing the main fuse
The 60A fuse is WAY too small!!
The amplifier's Fuse is 80A
You will want the MINIMUM battery fuse @ 80A as well.
Since the current draw at the battery is greater because of the resistance of the wire - an 80A - 100A fuse is recommended.
The purpose of this fuse is to protect your BATTERY if something happens along the length of power wire.
What kind of "shop" are you using?? I would find another one!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 28, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Power good no green light no subs
Make sure you got a good ground. do not ground on painted surfaces! If you got power from battery, check the remote wire running to cd player. Hook up remote blue wire with the one for cd player. If you still have a problem and the fuse is good, then the amp is fried
Jan 30, 2009 | Hifonics Brutus BXi 1206D Car Audio...
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics bxi 1206d
make sure you have a 40 amp fuse in it
im going to try to describe this to you
to bridge a amp this is for 2 ch AMP
I 2 2 I
I 2 2 I
I I 22
I I 22
I I 22
I I 22
Feb 11, 2008 | Hifonics Brutus BXi 1206D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Feb 23, 2007 | Hifonics BXI 1606D Car Audio Amplifier
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
459 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
