Question about Fuji FinePix F10 Digital Camera
Lens (lens cover?) only opens halfway
This is the second time this has happened to me. The silver lens cover only opens halfway. The last time it happened, fujifilm took my camera for 6+ months, made me pay a ton, and then gave up and gave me a new one. Any advice?? or ANY advice on how to break the silver cover so I can take pictures?
  • dhurtado Jul 20, 2008
    this happened to me once and fixed it but now I have the same problem but I have not figured it out how to fix it again. Any suggestions?
  • Anonymous Aug 23, 2008
    Hmm, this has happened to me too now. And just like the previous two posters it happened to me once before, but after switching it on and off a couple of times it corrected itself.
    Now, about a month later, it has happened again. And this time it doesn't seem like it's going to open fully any more. Out of interest how long have others had their camera before this happened? How many photos had they taken?
    Bobster
Bobster
Posted on Aug 23, 2008
I had this problem and just tried Solution #2 by a guest. I turned the camera off so the lens was retracted and the cover closed. I blasted a few puffs from a can of MG Chemicals Super Duster 152 directly at the closed cover. Then I turned the camera on and, voila, the camera is now working beautifully. Be sure to use a can of some brand of duster and don't use compressed air from any kind of compressor. The cans do not contain air but a chemical that comes out as a clean vapor that leaves no residue. Contaminents can come out of an air compressor that could make the problem worse.
Posted on Jul 24, 2009
I had same problem with my F10, lens cover only opening half way. I used a can of compressed air, just a couple of puffs or bursts directly on the closed lens cover seems to have fixed the problem. Probabably a spec of dust/dirt making the lens cover stick a little.
FYI - The brand is called Dust Destroyer, got at Staples.
Posted on Sep 20, 2008
If it opens only halfway it is being blocked by some dirt. just power you cam on and get the objective driven out. then pull carefully the cap on the front of the objective off. now you can take the mechanism apart and clean everything. put it back together and everything is fine...
Posted on Aug 28, 2008
The lens cover does not open or close completely. just started happening. the camera is 2 years old and the battery is fully charged
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 26, 2009 | Cameras
Lens error When the camera is switched on the lens does not open out and the lens cover does not open. The camera then displays a "lens error" message and suggests that the camera be restarted ten...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
It happens when you open the lens
Hi!
It's a stabilized problem - happens to these cameras. You should contact your local Sony service center and ask how much will cost lens replacement. If they ask too much, you can contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Jul 20, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Lense will not close properly
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Apr 25, 2008 | Canon PowerShot A70 Digital Camera
Lense Cover Stuck
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Camera lens cover is sticky
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Aug 23, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Optio 450 Lens Stuck Problem
the lens cover gets stuck sometimes. It just needs a gentle touch and it opens up. Only happened once to me. In my case it happened after my daughter held onto the camera with her finger on the lens cover.
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Fuji FinePix F10 Digital Camera Logo
295 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
