Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi tv model wt 46809
Hello I am trying to help out some friends who recently purchased the TV listed above. The problem is that the TV has a smudge mark in the screen it is almost like a rub mark is there a way to get this out with out doing furtheer damage and can you tell me what the screen is made of?
Thanks for the help,
Sam
  • Rucadog Jul 15, 2008
    Thanks for the response I do appreciate your imput and it may be a "smudge" or it may be a scratch but at least I can let them know where to start with it. You are the greatest. By the way do you know what the screen is made of?
  • 927 Answers
Good Day, sam;
Sam it depends on "smudge".
If it's an oily type; then a mild soap, like dawn, on damp, warm soft cotton type cloth may remove it.
There are products found in most large best buy, circuit stores that sell a screen cleaner. It's sold in a small spay bottle, about 2-3 ounces. Always spray onto cloth NOT screen. Always wipe/clean with up & down strokes, NOT side to side or at an angle.
If the screen is smudged after attempts of trying to 'cleanning' a scratch, then only replacing the screen will fixya problem, cost will be in the range of $100.00-$250.00.
Good Luck, hope this was helpful, big IRISH.
Posted on Jul 15, 2008
  • MICHAEL MULLINS Jul 16, 2008
    Good Day,sam;
    Not sure the name of plexi-type glass...sorry.
    big IRISH.
Wt-46809 has convergance issues
Replacing the Convergence IC's should do the trick. But it is not a easy repair do to the disassembly requierments. I would recommend calling Mitsubishi at 18003322119 to get a local service facility to come out and give you a estimate to repair.
Jun 21, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Convergence
hello theres a couple of codes you can try .1-2-7-0/2-4-5-7/0-3-5-3 /0-3-5-7 do not use the reset it may cause damage ti the tv good luck
shaun
Apr 10, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT-46809 will not stay on
Good Day, dimen;
This looks great. Check this out;
SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 pitcure is gone
your tech didnt know what he was talking about because that model usually only has problems with bad compacitors which is usually a very inexspensive fix however if he replaced the chip he probably replaced the eprong and failed to reprogram I would recomend you getting a service manual for your tv with online free tech support that wll try to help you straighten out this problem because it would be much cheaper than replacing either the board or your tv you may be able to fix this yourself with the tech support or at worse case senerio the tech will be able to get you a new board for a lot less than 500.00
heres the link
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Thanks for your help with the Mitsubishi WT 46809 but, there is more:
Fuses and IC's are soldered in on large PC board in center of chassis....
Your model is a tight fit that is usually repaired by chassis pull first, then
board repair, normally by a skilled Mits tech........
Oct 11, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
206 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
