Question about Brother Office Equipment & Supplies
I have a Brother Fax-920 which gives an 8 beep error signal. What does this mean and how do I fix it?
Spoke to the manufacturer and he said 8-beeps at a steady pitch indicate a problem with the sending fax machine not with mine.
Posted on Jul 15, 2008
How do I replace the pf kit on a brother mfc-9325cw. I have the replacement parts.
Laura, you get the necessary tools, get access and remove the old parts and replace with new ones. Make sense?
Jan 10, 2017 | Brother International Brother MFC-9325CW...
I have a schumacher xp2260 and am getting an error code of r02 but cannot find any information about it. Please tell me what it means and how to fix it.
I have no information on this fault. I suggest you contact the manufacturer directly with the question, but really doubt it will be something you can fix yourself.
Jan 09, 2017 | Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Is 0.08 less than 6%
Bot are numbers that are written in two different representations. To compare them safely you must convert them to the same representation.
0.08=8/100 or 8%
Now compare 8 % and 6%
Another way to do it is to convert 6% to its decimal representation then compare it to 0.08
6%=6/100=0.06
Since we have fractions let us just compare them. When comparing fractions, we first convert them to the same denominator (here it is 100). The greater one is the one with the greater numerator: 8 is greater than 6.
Conclusion: No, 0.08 is not less than 6%
Nov 05, 2013 | Office Equipment & Supplies
Mfc-j630w error messagfe 4f
I don't know but I can't enter into maintenence mode I pressed just as its said but it's won't go and I really need my printer??
Jul 15, 2012 | Brother Multi-Function Center MFC-3360c...
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
81 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
