Hello my washing machine sometimes wont start or win it does start it goes for like 10 seconds then stops and starts beeping and the water temperature lights keep flashing, sometimes opening the lid and closing it again works other times it doesn't for instance like now it wont start
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
913T is a very old model (1996), I have one, I'm not a repairer, I have the same fault. It doesn't have drawers or infrared or a display.
I've just shortened the ribbon cable, which had pinch damage at the door close pinch point. I used a male & female ribbon squeeze connector pair to make a good clean joint. With the cable fault it wasn't even starting the drain cycle. Now it does start, but then long beeps, and I suspect it's detecting a fault with the motor or a sensor or faulty wire, and is halting.
I've found running the rinse cycle first then allows the main wash cycle to run, no longer stopping at 10 seconds (after the initial drain), just as the first power wash commences.
Hello there:
FL
Flood Condition
FL
flashes
if any overfill condition occurs. This condition
occurs
when excessive water in the tub causes the
overfill switch
to trip. The control must realize that the trip
was due
to an overfill condition instead of a suds lack
condition
in order for FL to be displayed
With an overfill condition, the beeper repeats a
warning
every 10 seconds with no time-out. The pump is
cycled in
drain mode for 30 seconds on, 30 seconds off until
the overfill
switch resets or power is discontinued to the
unit.
Press STOP/CANCEL to clear the display. You may want to have the water level sensor replaced cause this will cause this condition if it is faulty ok Hope this is very helpful for you Best regards mike
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
well i don't have any experiencewiththis brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
