Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP5063W Tv
I replaced the color wheel and the tv still wont start up. I get a flashing lamp. I replaced the lamp too, turn on the tv and get the same. Any ideas?
While replacing the color wheel you know you see two cords running from it the blue/white cord and that copper cord. if you replaced both the color wheel and lamp, then it could be that copper cord just switch it around i did that and now my tv works
Posted on May 25, 2013
    Champion:
  • 217 Answers
Sound like a DMD board problem
Posted on Jul 18, 2008
Hlp5063w lamp and temp lights blink and tv doesnt turn on
Look at turn on to see if lamp fires even for a second.
If lamp has not been replaced in 2,000 hrs it is a suspect.
If you heard a high pitched whine or fan like noise before the set failed remove the lamp and look where it faces----is the color wheel shattered or missing pieces?
Apr 11, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
HLR6167WAX/XAA samsung tv wont turn on i already replace the lamp and the ballast but i still get the flaashing light
Tv also have a colors wheel.Now u turn the tv on,u hear squiling,motor or whinning noises?Yes,the colors wheel is dead,replaced the colors wheel.The tv will,work agian.
Aug 05, 2010 | Samsung Televison & Video
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
Jan 14, 2010 | Samsung - Projection TV replacement lamp...
Have lamp cooling fan noise on Samsung HLP5063W - 50 when I turn on TV and screen is distorted. Noise on TV is gradually getting worse and now does not go away and I essentially have no picture. Do I need...
the problem with your tv is the color wheel
not the fan let me know if you need help to take it apart...
I do repairs for samsung tv and I fixed a lot of them before..
Jul 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
160 people viewed this question
Henry  Thomas
Henry Thomas
