Question about iRobot Vacuums
MY SCOOBA RUNS AROUND ERRATICALLY BACK AND FORTH THEN BEEPS 5 TIMES AND SHOWS I AM STUCK
  • betoncat Feb 08, 2009
    My Dirt Dog starts and then wiggles back and forth moving forward, turns, wiggles the same, turns, wiggles, turns, wiggles.....then turns off. Sometimes I can get it to do the contour of a room for a bit, but then it stops and beeps again. We bought two and used one and put one away for when we needed it, and a year later, the first one started doing dancing, front/back/front/back....stop. So we pulled out the new one and it started the wiggling! This one is brand new, but not under warranty due to just now opening. We tried testing it, but it just sits there with the light on. It will do some of the testing, but not all of it. Is there anyway to find out if it is in the programming? Does irobot have any software you can download to it? Seems like it would have to be in the programming.
2 Suggested Answers
  • 3 Answers
SOURCE: scooba
Ensure that the front caster can spin freely, pivot, and rotate. Remove the caster by pulling it out and clear any dirt. Reinsert the wheel and lightly push the wheel up and down
Posted on May 18, 2009
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    Roomba 560 won't run correctly
    Hey
    if it's 5 beeps it says: Drive wheel is stuck
    You should clean both , push both in and out and confirm it turns freely
    Good luck
    Avi
    Feb 24, 2010 | iRobot Roomba 560 Robotic Vacuum
    My scooba seems to work fine but no longer makes the beeping noise. Several weeks ago the beep was sounding very strange almost like a battery was dying. Now it's not making any noise at all. Is this the...
    Your speaker went out. It could be totally isolated. You're not going to be able to determine what's wrong with your Scooba if something does happen, though, because without those beep codes, there's no way for the robot to communicate with you.
    If you're under warranty, call support at 1-877-855-8593 and let them know your speaker went out.
    Jun 28, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
    Scooba won't turn on
    It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
    May 08, 2009 | iRobot 5800 Scooba Vacuum
    When i charge,the service light is on and beeping
    get back to the person that you bought it from i would think they would give you some kind of waranty.i don't trust buying from ebay .i hope you didn't pay a whole lot for it.send an email to ebay themselves.please leave feedback
    May 04, 2009 | iRobot 5800 Scooba Vacuum
    I fixed my scooba's check tank problem, now it has the service light on and keeps beeping 4 times
    amber it might be a valve stuck get a straw and blow air into the solution valve under tank on right or try droping scooba 2 inches from ground as this might reset the ball valve .
    Apr 25, 2009 | iRobot 5800 Scooba Vacuum
    Scooba
    Jun 30, 2008 | iRobot 5800 Scooba Vacuum
    Stuck on check tank indicator
    If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
    1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
    2. Remove and reseat the brush head
    3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
    4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
    5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
    6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
    With the tank removed, press the Power button and then the Clean button.
    If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
    If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
    Below is a link to a diagram of these steps for visual reference:
    Title: Scooba is not putting down cleaning solution
    http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
    Nov 01, 2007 | iRobot 5800 Scooba Vacuum
    Scooba 5800 Power button Red Blinking (Continued)
    As for which one has the problem, I would say it has to be the battery. Rechargeable batteries of all types are known to have similar characteristics, one of which is discharging the batteries to maintain good rechargeablility. At least one person has demonstrated this for the Scooba battery in the roombareview.com forums when he brought a "dead" battery back to life. He allowed the battery to slowly and completely discharge using a 12-volt automobile bulb, followed by recharging the battery on the Scooba external charger. This procedure brought his "dead" battery back to a full charge! However, other forum members have reported that many have experienced problems with Scooba battery life, and that as a consequence of this iRobot will replace your battery if you call them and report a short-life battery problem. You can contact iRobot at (800) 727-9077 if you would like to report a battery problem and request a replacement.
    Aug 07, 2007 | iRobot 5800 Scooba Vacuum
    Scooba doesn't put watter. Pump not working?
    I calledthe company and they told me to forcefully flush warm water repeatedly through the valve that is just  above  the brush release button the the mechanical part  of the scooba.  It may take 20 or 30 flushes (I used a turkey baster, iRobot suggested a children's nasal syringe) and "Scooby" is  running great.
    Jul 28, 2007 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
    Vacuums Logo
    96 people viewed this question
    Top iRobot Vacuums Experts
    Shehu Pro
    Shehu Pro
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
