Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Defective sony/intel cpu?
HI GUYS1
GOT THIS SONY 1.5GHZ CORE 2DUO FROM CIRCUIT CITY APPROX.5MONTHS AGO. VISTA TASK MANAGER,INTEL’S ID UTILITY,CPU-Z,& NORTON’S CHECK IT ALL SAY THE RIG IS ONLY DOING 997MHZ INSTEAD OF THE 1.5GHZ.THE MULTIPLIER IS FACTORY SET 2 6X INSTEAD OF 9X BUS SPEED IS 166MHZ.SO THAT LEADS ME 2 BELIEVE THIS IS A DEFECTIVE CPU THEY SOLD ME SAYING 1.5GHZ.TECH SUPPORT CAN’T/WON’T SHOW ME HOW 2 RESET THE MULTIPLIER.THEY’VE BEEN GIVING ME EXCUSES 4 WEEKS.THE BIOS/CMOS HAS NO SETTINGS 4 MULTIPLIER.WHAT SHOULD I DO?
    Problem Solver:
HI FIXYA
THE SONY TECH TEAM SENT ME A BUNCH OF INTEL BLOGS 2 READ I READ ONE ON SPEEDSTEP.APPARENTLY WHEN I PLACED MY VISTA L/TOP IN POWER SAVE MODE IT THROTTLED DOWN THE MULTIPLIER 2 6X FROM 9X THERBY REDUCING THE SPEED 2 997MHZ INSTEAD OF THE 1497MHZ. AFTER I READ THE ARTICLE I SWITCHED TO HIGH PERFORMANCE MODE & PRESTO THE MULTIPLIER & SPEED JUMPED UP.SO I HAVE RENEWED FAITH IN SONY.PLACE THIS IN YOUR DATABANK.ALSO PLEASE REMOVE MY THREADS.
Posted on Jul 15, 2008
    Problem Solver:
Sony tech support, refused 2 show me how 2 reset the multiplier.apparently their firmware has a multiplier of 6x locked in.nowhere in the bios/cmos can it be changed.intel says its suppose to be a 9x multiplier 2 achieve the 1500mhz.why would sony throttle down a 1.5ghz rig to 997mhz?they cpu must be defective & to stop it from blowing up on people they set the multiplier @ 6x.ok fine but don’t advertise it as a 1500mhz rig & make consumers think that’s the speed they’ll b getting.how many other u.s.citizens r unaware that they’ve been swindled/cheated/misled?what about a recall? What about some legal action against them?i’ve spent hours & hours e-mailing them & making phonecalls & they’re intent on acting as if they’ve done nothing wrong.
HOW CAN I TEST TO SEE IF MY CPU ARE WORKING
go into you BIOS on BOOT, usually when you PC starts up hit DEL key or F2 depending on what this motherboards CMOS, then got to CPU part of your BIOS. Utility way http://www.cpuid.com/softwares/cpu-z.html
also can go into process task manager>> and change process affinitys of process to test each core
Aug 11, 2014 | MSI H55M-P33 LGA 1156 Intel H55 Micro ATX...
Does a core duo processor fit into a P4MBMS
Hi, you can download a manual here:
http://mach-speed.net/support/index.php?option=com_content&task=view&id=197&Itemid=44
CPU Support: Fully Support Intel LGA 775 Pentium 4 CPU Up to 3.6Ghz
There could be a bios issue when supporting a dual core cpu.
You should read the manual carefully before you continue.
Good luck.
Sep 15, 2011 | Mach Speed Matrix P4MBMS Motherboard
Can i upgrade my pentium4 to core 2 dou with a d865glc motherboard?
Hi the compatible processors for this Intel Board are families under Intel® Pentium® 4
Extreme Edition,
Intel® Pentium® 4, Intel® Celeron® D,Intel® Celeron®. ITs not good for Core 2duo.
Feb 16, 2011 | Intel Computers & Internet
WHAT IS THE RATE OF &WHAT ARE THE OFFERS FOR THESE PRODUCTS? INTEL CORE 2DUO ,2GB RAM, 320 GB HDD, DVD WRITER ,KEYBOARD,MOUSE,20''TPT MONITOR,E-SCAN ACTIVITIES,HP PRINTERS 1007
Here are the rates of what they are selling average used
INTEL CORE 2DUO
$100
2gb ram
depends on type- ddr2 would day around $30
320 gb hdd again depends on type- SATA around $40
dvd burner $20
keyboard mouse combo $20
20" monitor 75
Mar 21, 2010 | Acer Computers & Internet
Keyboard characters stop showing
This will happens due to 2 reasons 1. Your memory is low. 2. Your system is infected with malware/spyware.
Check your CPU utilization in task manager. Should not utilize 100%.
For this you need to download Antimalware like malwarebytes and clean the entire system.
Or Have to increase the RAM.
Hope this will be usefull
Thanks & Regards Nanda Kishore.
Mar 16, 2009 | Microsoft Windows Vista Home Basic for PC
Audio driver
Hello here is a link to download the drivers for your motherboard
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839
I searched Google using the error code you provided and found this problem to be very common. The most common solution was this: [quote] open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) install realtek driver the realtek driver includes the UAA driver too. Good luck
Mar 07, 2009 | Intel DG31PR Motherboard
AMD vs Intel
your selected processor is so better than intel.amd provides better graphical support than intel.
Jan 14, 2009 | Computers & Internet
Motherboard driver
i lose my Merury Mainboard Cd i nead the Drivers for PI945GCM Can any one help
Oct 21, 2008 | Intel Motherboard
MULTIPLIER SET @ 6X INSTEAD OF 9X?
Ok first of all can I have the model of the unit? secondly usually when you first boot up the computer you can hit delete to enter the bios setup. Now unfortunately you have to hope that the multiplier is in the bios. Sometimes it is a jumper located on the actual motherboard. Once I get your model number I can assist you further. Try that first once in the bios look around to see what you can find. Also you can change it in power management in control panel. But they are probably correct most laptops do bump up the speed automatically. This helps to conserve power. Which you would want with your laptop.
Hope this helps.
Thanks,
Lee
Jul 14, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
108 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
