Question about JVC KS-AX704 Car Audio Amplifier
Output cycles in and out. Amp runs extremely hot
Just recently the amp's output tends to come in and out. 2 seconds on...2 seconds off... and so on. Giving it a slight tap tends to fix the problem temporarily until vibration knocks it out of whack. I checked all the connections; everything looks good. Appears to be an internal problem as the amp runs very, very hot to the touch.
  • 25 Answers
Sounds like you have a bad solder connection somewhere inside the your amplifier. I would carefully open it up and check for lose parts (resistors, transistors, capacitors, diodes, etc). It is not that difficult to do. Once you find the lose part, solder it into plce with a liberal amount of solder. That should solve your problem.
Posted on Jul 17, 2008
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
Jan 26, 2013 | Car Audio & Video
I just bought two rockford fosgate t1 twelves duel voice coil 4ohm I'm running a old school alpine v12 1507 mrv 2channel. I want to bridge the amp to get the most out of these subs would it be better...
This amp should run comfortable at 2 ohms/channel. However, your dual voice coil subs are rated at 4 ohms. This means when you connect the 2 voice coils together in parellel (positive to positive and negative to negative both coils wired to one output) the amp will see 2 ohms. So if you connect both subs to one output then your amp will see 1 ohm (not good) If you run the voice coils in parellel but the subs in series then the 2 resistances (ohms) will be added together. So that way the amp will se 4 ohms. This is fine but the amp would push more power into 2 ohms. You can run one sub on each channel if you can split the head unit output to 2 outputs, problem is then you will be halving the amount of power to each channel. Personally I would probably be more inclined to run 1 sub on this amp and run another amp from the pre-outs on the first amp for the 2nd sub. Try to find another amp the same to run the second sub. Mind you, 2 of these amps will need some big power cable to run them but should shake your teeth out!
Hope this helps
May 08, 2011 | Alpine Car Audio & Video
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My amp goes into protection mode when i turn on my car. It gets hot too. I had 2 kicker 12" l5's and blew the subs with that amp, could i just have a simple problem with the amp? What are all my options?
Protection LED on, no output? Amplifi er is very hot = thermal protection is engaged. Test for proper
impedance at the speaker terminals with a VOM meter (see the diagrams in this manual for minimum
recommended impedance and multiple speaker wiring suggestions). Also check for adequate airfl ow around
the amplifi er. Amplifi er shuts down only while vehicle is running = voltage protection circuitry is engaged.
Voltage to the amplifi er is not within the 10–16 volt operating range. Have the vehicle’s charging and electrical
system inspected. Amplifi er will only play at low volume levels = short circuit protection is engaged. Check
for speaker wires shorted to each other or to the vehicle chassis. Check for damaged speakers or speaker(s)
operating below the minimum recommended impedance.
No or low output? Check the balance control on source unit Check the RCA (or speaker input) and
speaker output connections.
Jan 29, 2010 | Kicker ZX10001 Car Audio Amplifier
2 amps, 1 signal, will one work if the other doesn't?
You will have to have power to the first amp in the chain for sure so that the output signal will be there. Without power, there will be no signal.
Sep 26, 2009 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
How can i get this amp out of protection mode?
You have a short circuit. I don`t know this particular piece of equipment but you should check all the output transistors/chips. Try disconnecting ALL the supplies to ALL the output devices and switch on, It should fire up, If it does, reconnect the positive AND negative supplies to one channel. If it still fires up, reconnect the next channel until you find the faulty channel then you could try doing comparison checks between the bad channel one of the good ones. These amps tend to use MOSFETS and are extremely intolerant to bad or loose connections. I hope this helps. You`ll probably find that you`ve got poor wiring, That will be your original fault. Ensure you make ALL connections good and sound before reconnecting the amp up with new devices in or you WILL be back at square one with no amp again. Ian
Jul 19, 2009 | AudioBahn A8001DT Car Audio Amplifier
Kenwood KR-4010 (late 70's vintage) with signal to IF amp but no output
Don't bypass the relay contacts. They serve to disconnect the amp stages from the speaker if a DC condition is present, and in doing that, save your speakers form damage. Check for a DC offset condition on the junction of the emmitter stabilizer resistors to the STK0040 on each channel. They will be 0.47 ohm power resistors(2 per STK) connected to pins 3 and 8 of the STK. Anything substantially greater that 100mv here generally indicates a blown STK. Don't bother to change both, but just the one that is faulty. Another common problem for this age of amp. The high silver content in the legs of the transistors allows for "growth" between legs and internal connections of the transistor. Check for "black death" on the legs of transistors driving the STK. . . I tend to replace them if in doubt. If you need expert advice, comment me back. I am an audio specialist.
Feb 03, 2008 | Audio Players & Recorders
Wiring woofers
Well, you have the 4 ohm dvc kickers, and your amp being stable to 2 ohms doesn't go together very well. If you wire the voice coils in series, and hook the speakers to the amp in parallel, you get 4 ohms, which doesn't use all the power your amp is capable of. If you run the voice coils and the speakers in parallel, you'll drop the resistance to 1 ohm, and probably fry the amp, or at least deal with overheating issues. Better be safe than sorry. You need to run each speaker in series, which means running a positive and negative to each speaker, and a jumper from those terminals to the opposite colored terminals on the second voice coil. Diagram can be seen here: http://www.kicker.com/06/tech-support/manuals/manuals/02SoloBaricL7manual.pdf That puts two 4ohm voice coils in series, and raises the resistance of each speaker to 8 ohms. Then, you have to run both speakers in parallel to the amp. When you run two 8 ohm circuits in parallel, the total resistance of the circuit is 4 ohms. That means seperate positive and negative wires to each speaker. If it is a mono amp, connect both negatives to the negative output, both positives to the positive output. If it is a multi-channel bridgeable amp, You'll probably connect the negatives to one side output (right for example) then connect the positives to the opposite side output (left for example). If you need to bridge your amp, make sure it is bridgeable, and also that you have the speakers bridged to the proper amp outputs. If not sure, reply back here with the amp model number, and maybe I can help you further.Thanks, and I hope this solves your problem.
Nov 29, 2007 | Kicker 02S10L74 Car Subwoofer
Boss 2500d gets hot and trips off and on every 5 mins...
If you are bridging the amp then you must DOUBLE the "ohms load" that is specified. I.E. If you need 4ohms per channel, then when bridged you would need 8ohms per bridged channel. If your load is indeed correct then you have a fried output probably. Try to run it without any speakers on it. If it still gets hot then you for sure have a fried amp. All the symptoms you decribe sound just like you have too much of an "ohms load" though.
Aug 01, 2007 | Boss Riot 2500D Car Audio Amplifier
JVC KS-AX704 Car Audio Amplifier Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
