Question about Motorola Mobility E365 Cellular Phone
Battery + battery cover issue.
The back black cover that thats guards the battery got broken and the battery surface seems to be a bit portruded out .probably thats the reason why it coul have got broken .Its been over 4 years of me using the phone . The battery has been working well since then . what do i do now ?
    Master:
  • 726 Answers
I had a look at your phone and its sorta old now so you could buy a new battery and cover for about 25 dollars or the best thing would be to buy a newer phone as there so cheap these days the battery on yours has expanded because you have had it for 4 yrs of charging,being in the sun,usage all those reasons
Posted on Jul 15, 2008
How can I reinsert bobbin race back into my elna su 68?
Hey I can help you with this, its a long detailed explanation though. Have you removed the bobbin holden, ie,undone two small screws and lifted out the silver bobbin case, leaving a black round thing? This black bit is the lower ring guard, you have probably undone this to remove a thread caught in the edge of the bobbin case or umderneath. Elna manuals never detailed cleaning here but it is simple enough and needs doing from time to time, i have seen big wads of felted threads and lint under guard rings when pulling apart machines. This video shows how to line up the lower guard ring, the outer casing and the bobbin case.
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
I always turn the flywheel until the opening of the lower casing is facing forward, then look at the black lower guard ring and turn it until the cut out bit is facing the front. Now look a the bobbin case, it has a couple of silver Beaks and these need to fit in between the stoppers on the outer case. You will know if lined up right as it just fits straight in, wiggle a bit left or right until its lined up. Those two silver screws have to marry up with the two holes in the lower guard ring.
Once aligned , tighten up the two screws until firm. There is a dark coloured screw too, leave it alone.
Hope,is helps, once youve done this a couple of times, its easy.
Sep 04, 2014 | Elna Sewing Machines
How to fix my mp3 when it wont turn on
1. If on warranty, rerturn it
2. Either let the battery just die, (because it will just die, and turn off, and you should be able to turn it back on) or, you can open up the battery, take it out, and put it back in. that worked for me.
another thing, is you COULD try to hook it up to the computer, but i am not sure that fixes it. but you can always try. hope i helped!
3. Pull it apart. carefully lever off the cover from the power switch, and remove the small broken bit of black plastic. (it's that broken bit that is your problem.) BE CAREFULL not to disturb the small round metal contact.
now when you poke the small round metal contact you should hear it click as it turns on and off.
to be able to do this when you've put the covers back on, drill a small hole in the back cover above where the contact is. Then you can turn on/off the player by poking a paper clip through the hole.
Jul 02, 2014 | Coby MP601 MP3 Player
Im changing the spring in the guard of our 6"ridgid jointer it seems like there is a bend in the spring that fits thru a hole in the top plate??the manual does not show this process can you...
I'm not at the shop to look at mine, but they're all pretty much the same. It definitely hooks through the hole in the guard itself, and also in my case (a powermatic) to short length of grip chain. It seems to me there's a better way to hook the spring on, so that it rides a little above the surface of the jointer when in play, and doesn't score a path across the bed as the guard moves back and forth. But with a little trial and error you have no doubt already long since figured this out.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 21, 2011 | Masonry Tools
How do you replace the cover that has the spring-band chain break? I can't seem to get it over the clutch. There must be a trick.
You need to load the brake, it has obviously activated and the band is now smaller than the drum, if the hand guard is connected to the brake, clamp the side cover in a vive, be carefull not to damage the cover, now pull the hand guard fully back, it will take some force as it is compressing a large spring, it will click when the brake loads, if the hand gaurd is on the machine not the brake, remove the hand guard from the machine and use this as a tool to fit into the brake, with the cover in a vice pull the hand guard fully back until it clicks. the cover should now fit back onto the saw.
Apr 09, 2011 | Husqvarna Garden
How do you remove Routers on a 1997 Frod F150
PB Blast the hubs where the lug nut studs portrude thru, and the center of the hub. Then get a BFH and come in frome the back, beat and rotate. Clean mating surfaces good b4 installing new rotor.
Feb 05, 2011 | Ford F-150 Cars & Trucks
How to change the spool in the black and decker grasshog
Is this the cordless Grass Hog? Turn the trimmer upside down so you're looking at the bottom. There are two orange tabs on either side of the spool -- push these in and the head should pop up so you can pull it out.
On the new spool, feed the cord out several inches and stick it through the hole in the trimmer where the old cord stuck out. Then pop the spool into the cavity so that the orange cover faces out (toward you). Pull the cord taut and make sure it is not long enough to hit the plastic guard. If it is too long and it touches the guard, pull the spool off and wind the cord in a little bit. If the cord is too short, pull the spool off and thread out a little bit more length and try again.
Turn the trimmer right side up and turn it on to make sure it works. If you hear a loud rapid thumping sound that sounds sort of like a machine gun, the cord is too long and is hitting the plastic guard.
Jul 04, 2010 | Black & Decker 14" Grass Hog Xp...
BLACK LINE DOWN DOW PAPER
If this problem is on a laser printer there is only one thing causing the issue.
More than likely there is a permanent scratch in the surface of the image drum that goes all the way around the cylinder.
To verify this simply remove the toner cartridge from the unit and turn it over. You should see a small plastic shutter mechanism which is covering the photosensitive drum. Carefully open the cover without touching the drum surface with your fingers as the oils on your skin will damage the drum surface further. If you see a mark in the drum surface, that is your problem and the toner/drum unit will need to be replaced. This most likely was caused by something that was accidentally introduced into the imaging area of the unit. Before putting a new toner/drum cartridge into your printer verify that there are no obstructions like a paperclip or even smaller a staple as this will get caught in the new unit and cause the same problem. This problem is not covered by manufacture warranty and therefore you will need to bit the bullet and buy a new one.
Hope this helps solve your problem. I used to work as a Systems Engineer for Kyocera-Mita a printer and copier manufacturer so I have seen this issue hundreds of times over the past 20 years.
Cheers,
Keith
Oct 21, 2008 | Office Equipment & Supplies
No Battery Life
On mine, the battery terminal on the inside of the battery case is broken, by opening and shutting the cover a few times until it contacts properly it is normally OK. Anyone know where I can buy a new contact plate in theUK?
Nov 10, 2007 | Casio Exilim EX-Z120 Digital Camera
Panaboard KX-B530
I had the same problem on mine.I found it was due to the vertical height of an aluminum window plate, that is attached in front of the CCD optical sensor box, this box is located inside the back aluminum enclosure.
You have to unscrew the back cover and slide it out sideways, be carefull becasue the back cover is heavy and you don't want that falling on someones toes. Also there is some strong adhesive tape holding the cover to the enclosure so you'll have to pry on it a bit to pull the tape loose.
Once you have the cover off, you will be able to see the optical sensor box that is on the far side where the two guard bars (the flat aluminum bars that hold the back panel in place) the two guard bars meet on the one side Like a V.
Right where the bars meet and the V, you should be able to see the small optical box that has a small **** on the face of it and has two small screws on each side of this **** or "window". This is the Window for the optical sensor to pick up the image it is scanning which is a reflection on a mirror that is located on the opposite side of the enclosure. This mirror is about the size of a standard classroom meter stick and it reflects the scribbles of the panaboard surface as the canvas rolls around durring the scanning phase.
If you uncrew the two small screws that are on each side of the Optical sensor window, you will notice that this Window plate will be able to slide back and forth. Adjut this window plate hight and try printing another page and see how the image looks. If the Black bars are bigger then you have moved the plate the wrong way. Readjust and try again. Once you make the proper adjustments the black bars will no longer appear.
Well, this is what fixed mine, so hopefully this will help you.
Regards,
Gerry O'Brien
email: gerryob AT digital-circuitry DOT com
Oct 01, 2007 | Panasonic Panaboard KX-B530 Graphic Tablet
Andis masters are chewing my guards
Stop using speedo guards and get yourself an oster 76 and all the blades.
Aug 16, 2007 | Andis 01690 Hair Trimmer
Motorola Mobility E365 Cellular Phone Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
