Question about Xtant A3001 Car Audio Amplifier
One sub working other is not
Hi i ihave 2 12 legacy sapphire subs with a sanyo amp and one sub just stopped working while the other stll hits, could this be because of the speaker blown or just loose wiring or is there other problems that could have happened?
  • 1,498 Answers
Lets narrow it down.
You've go two speakers, one works, one doesn't.
First off, switch the connections on the speakers.
- Good to bad
- Bad to good
Now, if the one that wasn't working, starts working: The speaker is OK
If the one the was working, still works: The Amp is OK
If the one the was working, stops working: Either the amp input for that channel has been compromised (check connections), That side of the amp is blown, or possibly (long shot) the heads balance is all the way to one side.
If they both are working: It fixed itself!!
Hope this helps locate the problem
Mike
Posted on Jul 20, 2008
I have 2 solo baric l7 duel 4ohm subs and a legacy la-2499 amp.What is the best way to wire it up?
Unfortunately, the amp is only 2 ohm stable, so the best option is to connect each subs voice coils in parallel (2 ohms) and connect the subs in series (4 ohms).
Oct 06, 2015 | Legacy Car Audio & Video
Legacy 1000w 2 channel amp worked awesmoe then just stopped working after a few songs. Didn't turn up too loud. Didn't have the settings too high. still getting power (amp light on, led lights...
Open your speaker box up most likely the jumper from the inside of the box to the subwoofer itsself is broken free, Usally when they have lights around the sub woofers there seperate leads, bet 10-1 you have loose wires inside the speaker box
Mar 25, 2013 | Legacy Audio ICON LA2770BK 1000W 2-Channel...
Sub and amp cutout
i guess you need to check the watts of your amp and sub, maybe it not match the power of both item.
Jul 27, 2012 | Legacy Car Audio & Video
Legacy LA770 worked for 2 10" subs but not for 1 12" sub
if the protect light is still on with all speakers disconected then you have overloaded the internal ic and blown it beyound its ability to reset
sorry
Jun 25, 2010 | Legacy Audio LA770 Car Audio Amplifier
I have 2 kicker cvr12s and a legacy predator 2400 watt amp and when I turn the radio up the amp goes into protection once they hit a decent time. I just down graded from 15s so I know its not a power...
you prolly have the subs wired to a too low of an ohm load...thats what happend to me. i had the same subs, and a 500.1 watt amp...and they still blew up..whire EACH sub to a 4 ohm...that should work.
Nov 18, 2009 | Car Audio & Video
My sub is making a wierd noise when i crank it up
you might be over powering the sub, turn your amp down a little bit
Aug 13, 2009 | Legacy Audio LW109 Car Subwoofer
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Subwoofer stopped working
Put another known working speaker in there to see if it works. If it does then the issue is with your speaker. If it also does not work your amp is to blame.
Sep 16, 2017 | Alpine SWR-1222D 12" Type-R Series...
Sub hits backwards, hi low level converter?
I ran into a similar problem installing a sustem in a Mazda RX8. He had BOSE speakers which operate at a different range. We had to purchase the Rockford 3sixty.
Apr 20, 2009 | Scosche Industries Scosche Slc4 Speaker...
ONLY ONE SUB IS WORKING
did you try to switch channels with the subs and see if it is the channel on the amp. if it works then its the sub and it will need replaced
Apr 01, 2008 | Jl Audio 12W3 Car Subwoofer
Xtant A3001 Car Audio Amplifier Logo
80 people viewed this question
Top Xtant Car Audio & Video Experts
hoyzee1
Tom Chichester
FastHarley
FastHarley
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
