Question about Lands Phones
How do I untap my phone that I think is tapped?
  • 97 Answers
Do a tap dance, ring your service provider.
Posted on Jul 15, 2008
    Master:
  • 726 Answers
If its taped u on a police watchout they want to listen in on you
or you have crossed lines with some one
dont do a tap dance rocky89 is a idiot service provider cant help either
Posted on Jul 18, 2008
2 Suggested Answers
SOURCE: my cell phone is tapped.
Go to the police station and have them look into it. It is against the law for people other than the government for legeal issues to tap into your cell phone
Posted on Feb 26, 2011
How can I delete Apps from my mobile phone Memory near full.
What kind of mobile phone do you have? If you're on an iPhone, then here's a guide to help you delete apps.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
To delete an app, tap the X, then tap Delete in the dialog the displays. Note that doing so deletes not only the app, but also all of its data. So if you think you'll need an app again soon, and you have stored data, settings or completed levels for it, you might want to think twice before tapping that X.
http://www.leawo.org/tutorial/how-to-delete-apps-from-iphone.html
Dec 07, 2016 | Cell Phones
Untapping my phone
untapping what or by who
Aug 03, 2016 | Cell Phones
My Zte phone say low in space cannot use text message, Facebook or Pinterest
Steps to clear application cache on your ZTE FuryClearing the application cache removes temporary files and frees up memory - your personal settings or information remain intact.
Be sure you clear only the application cache and not the application data.
  1. From the home screen, tap the Menu key.
  2. Tap Settings.
  3. Scroll to and tap Applications.
  4. Tap Manage applications.
  5. Tap the All tab.
  6. Scroll to and tap the preferred application.
  7. Tap Clear cache.
  8. You've now cleared the application cache.
Jun 06, 2016 | ZTE Cell Phones
Don't hit it with your fingers?
Nov 04, 2014 | ZTE Cell Phones
What app do I need to untap my phone
you dont... burner phone time
Mar 19, 2014 | Cell Phones
Screen dissapears after activating call
possibly solution
1.hard reset your device
2.otherwise it maybe hardware issue (touch screen problem)
for : hard reset on the start screen tap -> button then tap setting then about phone, then tap reset your phone and tap yes.
touch screen issue : you need to take to some technician to disassembly to touch screen and reassembly again if with this not solved you will need to change the touch screen. i think this will help you.
Jun 20, 2012 | Nokia Lumia 710
Suddenly I have zero power to my door locks, side mirrors, and power windows. It's an F150 with a 5.4 liter engine. Where exactly is the panel for this/these problems?
passenger side kick plate. pull the harness out, untape it and dry it offlook for the orange wire, i beleive its got a green stripe down it, it should splice into 2 wires about 5 inches away from the door hinges. untape the splice and you have found your corrosion problem. cut the green out and splice it all back together. good luck
Sep 10, 2011 | 2005 Ford F-150
I have no harness for vehical was told the reason I have no sound is becuase the pink and black wire labeled Audio interrupt lead were does this connect 2
The install diagram indicates the Audio Interrupt wire goes to a Vehicle Phone. If you don't have one, don;t connect it to anything andmake sure you put tape over the end so it doesn't touch ground or a power source.
In cases where I don't have or cannot get a wiring harness adapter to plug directly into my vehicle wiring harness I have a trick I like to use. I don't like to cut and remove a vehicle harness socket, I may want to keep the aftermarket stereo when I sell or trade and put the original stereo back in place. Instead of removing the socket I skin back (but do not cut) the wires I need to tap into and wrap the aftermarket unit's wires around the now exposed socket wiring, then solder each one & wrap each one individually with electrical tape. This gives you a secure connection and when and if you need to permanently remove the aftermarket unit you just untape the wires, clip the fatermarket wires off one at a time very close to where they are tapped in, tape each one of them again and there you have the factory plug ready to plug back into the factory stereo.
Aug 20, 2011 | Alpine CDA-7892 CD Player
How to fix screen calibration on the phone?
Go to Menu>Settings>Phone>Calibration
Note: it doesn't always calibrate on the first touch on each point. It might take you many tries to get it to move to the next point.
It is best to do this operation with a Q-tip, which resembles a finger to the Eternity's software more than a sharp point, but is also more accurate than a finger.
To test the calibration, dial *#0*# and press "9"
If this did not fix your problem, or you think you have a hardware issue
Feb 28, 2011 | Samsung Eternity Cell Phone
My cell phone is tapped. how do I untap it?
Nov 03, 2010 | Lands Phones
Lands Phones Logo
1,526 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
