Question about Saeco Aroma Espresso Machine
Saeco aroma won't turn on, I tryed different plugs where appliances work.
  • Anonymous Mar 22, 2014
    Model b40had started leaking from somewhere but at some point it got unplugged and once plugged back will not turn on..I have tried plugging it in to a different plug that I know works but it will still not turn back on..suggestions
  • 515 Answers
Try to reset the thermostat.
Take off the water tank, now you will see two screw, one in each corner. Take off the top, now you will see the boiler.
There are one thermostat with a pin in the middle, push down this.
Put the top on again and the screw.
Hope this will help you.
Posted on Jul 15, 2008
  • Mike Lammens Sep 27, 2011
    I have the same problem but don't see any thermostat anywhere on the machine. Anyone got a picture of it? Thanks.
I have a saeco aroma coffee machine that will not turn on.. This machine has only two thermostats and no reset button visible. Could there be one inside the boiler or should I keep looking?
The Saeco Brand is under the Philips umbrella of companies. The Aroma line is not considered user serviceable beyond descaling and cleaning. However, most devices that heat water tend to have a fusible link somewhere in the power circuit. If you're already poking around inside, trace the power connection (obviously with the machine unplugged) through to the heating elements, sensors, etc. You might find a small "bit" that looks scorched or burnt.
Otherwise, it might be good to contact Saeco and see if there's an authorized repair center near you. The Aroma is definitely pricey enough not to just dump and replace like an old Mr. Coffee.
Jan 04, 2017 | Saeco Coffee Makers & Espresso Machines
My 3-year old Saeco Aroma blew the mains circuit when I switched it on this morning. I tried it on other circuits but it did the same. Is it worth the shipping and repair costs? Thanks, Aodan
Check the other postings on the topic of "blowing a breaker". Appears to be a heating element or boiler short. They don't recommend you fix yourself.
Mine is 13 - 14 months old and did the same thing two weeks ago. The words, "boat anchor", come to mind. Saeco won't honor it, and the online retailer wants $100.00 to receive it and supply parts - labor and all shipping is on me. I paid $235 for the unit, so you do the math as to whether its worth it. I'd say no.
Apr 16, 2011 | Saeco Aroma Espresso Machine
The steam light on my Saeco Aroma does not turn on (and no steam comes out), even after the brew light turns on and I press the steam button. How can I get my steam to work?
HI
It is probably your steam thermostat that needs to be replaced. There are 2 thermostats. The Brew and steam. If one of them fail it won't heat the boiler for that mode. They are easy to replace.
Oct 05, 2010 | Saeco Aroma Espresso Machine
No steam on saeco aroma redesign
Hi
That is probably you steam thermostat. Its a 127c thermostat.
Oct 27, 2009 | Saeco Aroma Espresso Machine
Saeco aroma compact SE 2GR turns on, but only heats the water.
I had replace my on off rocker switch on my aroma nero after a couple of years I was able to swap out my switch for heating the steam as a temporary fix I purchased a replacement switch from Sacco at that time but I think now you might have to go to a secondary parts dealer I have kept this machine a live for over 12 years and am now going back to it after fighting with my new automatic machine sure it was easy but the taste just was not the same the kids can have it they put so junk in their coffee how would they know pbjh2o@yahoo.com
Sep 05, 2009 | Saeco Aroma Espresso Machine
My saeco aroma was overheat and now it broke. I turn it on and it has never work again. How can I fixe it ?
I REALLY don't recommend trying to fix it yourself (usually parts are hard, if not impossible, to obtain, and in addition to that, if you DO try to fix it, and you CAN'T, and you're still under warranty, it would VOID your warranty!). I'd say try to contact Saeco, because if you do, usually they will have nifty little tricks for you to try that might fix it, and if it's not fixable, and you're still covered by their warranty, they might be able to replace it for you!
Their contact number should be either stamped somewhere on the machine (usually on the bottom--might be stamped directly into plastic, so make sure you have it in really good light when trying to read) or in the product manual (usually near the back of the book).
Good luck! :)
Aug 21, 2009 | Saeco Aroma Espresso Machine
My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Aug 22, 2008 | Saeco Aroma Espresso Machine
Saeco aroma
The boiler is broken, you have short circiute in the boiler
Jun 19, 2008 | Saeco Aroma Espresso Machine
Saeco Aroma Espresso pump not drawing water
Hi Espressoless,
You have to force in water to the machine, to this you need a bellow pump or similar and force it into the water tank inlet when you do a priming.
Dec 30, 2007 | Saeco Aroma Espresso Machine
Coffee Makers & Espresso Machines Logo
1,461 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
