Question about Sony PlayStation Portable (PSP) Console
The volume on my psp is no working and i need help fixing it
    Problem Solver:
  • 6 Answers
Yeah, that happens to my PSP too. Do you have a remote control for your PSP? If you do, then you can use your remote control volume. And that should work. If you don't have a remote control, then you should buy it. That's the only solution.
Posted on Jul 15, 2008
My volume dont work is there anyway i can troubleshoot it or restart the whole thing?
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
Feb 13, 2010 | Sony PlayStation Portable (PSP) Console
Tip
How to fix Volume issues in PSP Portable
on Feb 13, 2010 | Video Game Consoles & Games
My psp volume button will not work can you help but its only the one to turn it up not down
When this happens, it's because the volume button on the inside is messed up. Usually it's because it's dirty or sticky and sticks down [or presses itself]. You can try opening it and cleaning under the volume button. If that doesn't work, you may need to replace the home/volume/start/select circuit ribbon cable. If you're not comfortable opening it, check the following company -- they would repair something like this for $29
http://store.richspsxparts.com/clforpsprese.html
Nov 16, 2009 | Sony PlayStation Portable (PSP) Slim...
The volume button of my psp does not work
I think your volume button is broken because I had a similar problem with my psp My WiFi switch wont work when I had it checked the switch was detached from the command it was assigned to
May 20, 2009 | Sony PlayStation Portable (PSP) Console
My psp blacks out after hitting home key and volume doesn't work
Since the PSP is pretty much un-"do it yourself" fixable, I would call Sony or another electronics repair company to fix the PSP for you.
Dec 29, 2008 | Sony PlayStation Portable (PSP) Console
Wet psp volume and home does not work, can not recharge battery
Your PSP is bricked, and unfortunately this cannot be fixed because its a hardware brick. The PSP needs to be replaced.
Sorry
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
Volume
is easy just disable the AVS opcion en sound opcions
Sep 28, 2008 | Sony PlayStation Portable (PSP) Console
The vol. is not working on my psp
Make sure the volume is not set to zero. Try raising the volume using the volume buttons located on the front of the PSP.
Make sure the mute setting is not on. Press the (Music Note), third one from the right, located on the front of the PSP® to clear the mute setting.
If headphones are inserted, the PSP will not send any sound through the speakers. To check that the speakers work, unplug the headphones.
Hope that will Fix Ya!
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Psp keys
It sounds like the pc board that the volume buttons are in is damaged or coming loose. Aany repair shop that services PSP's should be able to fix that.
Sep 12, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
