Question about GE Profile JTP18 Electric Single Oven
Control Panel doesn't work
We are not getting any error messages, however all of the lights are lit up simultaneously and make our oven useless. At random the control panel will start working as almost as quickly will shut down again.
Any ideas?
    Problem Solver:
  • 10 Answers
Try fix found at  http://www.fixya.com/howto/h155060-dreaded_f7_error
It may work
Posted on Aug 18, 2008
Whirlpool super capacity 465
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
Rick
Sep 03, 2011 | Ovens
Unlocking Door Message - no buttons on the oven are working. How do i reset
For this type of error, there are a few different things which could be wrong. There is definitely a issue in the door lock circuit. Including in this circuit are the door latch mechanism, 2 or 3 switches on the door latch mechanism, the wiring harness which connects the mechanism to the Electronic Oven Control (EOC), and the Control Panel (if separate from the EOC).
The first step would be to off power to the oven. Turn the power back on after 2 to 5 minutes and if you are extremely lucky, the control will reset and cycle the door lock. This doesn't work very often.
If a hard reset does not resolve the problem. please respond with the make and full model # of the oven for further diagnosis.
May 01, 2011 | Ovens
My oven has power but it does not work. When I
Your control panel is faulty and will need to be replaced. You can get another one at repairclinic.com or partselect.com
Jan 13, 2010 | GE JKP15 Electric Single Oven
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
Unable to clear error message on panel...oven not operating
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#RET
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
Control Panel
there is no other way to get around that but to replae the control once agsin. It sounds like there are some stuck touchpads or the control itself is shorted. either way you need to replace it.
Aug 05, 2007 | GE JKP15 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
146 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
