Question about Philips GoGear HDD6330 MP3 Player
Ear plug ear phones will not work unless you're holding the jack and turn to a specific way and I have changed the earphones Stormy
  • 8,596 Answers
That is normal for most mp3 players
If you are getting sound out of only one ear, then the headphone jack is broke - unfortunately, Philips does not have any more HDD models to send you as a replacement
Posted on Aug 07, 2008
What can I do about my ear phone jack not working?
Earphone jack ... for changing a tire? Earphone jack on WHAT?
Apr 29, 2017 | Audio Players & Recorders
Why can't i get my earphone to work?
Plug them into the headphone jack of your device and play some music or make a call from your device and see (or rather hear) what happens next.
Oct 13, 2014 | Williams Sound EAR 041 Single In-ear Mini...
Samsung galaxy s3 headset icon shows and when
try cleaning up the headset hole in the phone using a cue-tip for ears. dry . and if the headset icon doesn't disappear un-plug and re-plug the jack eventually power off / on restarting the phone. see if this helps ;) good luck!
Oct 02, 2014 | Cell Phones
14 month old Ultimate Ears 700s and the jack has turned faulty. I can wiggle it around to get both phones to work, but, once I remove my hand from the jack, the right phone goes out. Is this fixable? ...
It is for sure that the wires have come out of the jack connection. This normally happens as the wires are always moved around as your plug and change.
The easy way out for you is to approach any electronics service center who can easily splice off the wires and put in a NEW jack which must be soldered.
This job can be done if you are able to handle a soldering iron and get to solder the jack with the connection on either terminals- just any tech will guide you to do this very easily.
Mar 08, 2011 | Ultimate Ears 700 Noise Isolating...
Hi, the headphone jack is not working at all! I have a Latitude D610. I've had the laptop from my company. Do you know how to address this problem? thank you very much
Does the main speakers work on the laptop? as you know when the headphones are plugged in, the internal speakers turn off. If the laptop speakers are fine then you have a problem with the ear phone jack, it needs to be replaced, or part of the original has broken free of the motherboard and needs to be resold-ed. If on the other hand you have no sound at all, the ear phone jack has comletely broken free or the audio ic is the problem. Regardless of the issues the laptop needs to be dis-assembled to address the problem.
Jan 07, 2011 | Dell Latitude D610 Notebook
I have turned the tv on and in the top right hand corner there is a symbol for earphones and i cant get the normal sound back on
yoiu likely have a sound output selection in you setup menu .. or in some sets they sense the fact that ear phones are plugged in (switch in the ear phone jack) .. and that automatically shuts off the main speakers .. sometimes the ear phone jack gets damaged and the set thinks there is always an earphone plugged in .. if thats the case then the jack would have to be replaced or repaired ... or you could for the time being, run a cable from the ear phone jack to an external amplified speaker (like a computer speaker .. that would get your sound back at least until repairs can be made ..
Nov 27, 2009 | Cell Phones
IPhone 3GS: suddenly music only on the left
hi. i can help you. begin by cleaning out the little hole your ear buds plug into. Carefully clean the jack hole with a needle or a tough pick. It allowed me to remove a lot of cotton like dust. if that doesnt solve it go into your phone menu under audio settings and see if you have adjusted the balance to cause your problem.
also, You can try removing any debris that might be in the headphone jack by plugging and unplugging the headphones a few times.
If the issue is not caused by debris in the headphone jack, request repair/replacement of the Apple Earphones with Mic online here: https://selfsolve.apple.com/GetWarranty.do
You can also request service by making a reservation with a Genius here: http://www.apple.com/retail/geniusbar/or call AppleCare U.S. iPhone technical support at: 1-800-MY-IPHONE (1-800-694-7466)
Nov 10, 2009 | Apple iPhone 3G
No ear speaker?
sometimes the phone thinks there are earphones plugged in try plugging earphones in then unplugging again also try volume up and down and it will display earphone on screen keep plugging in and out until it does not say earphone on volume
if that doesnt work restart phone
Jan 16, 2009 | Apple iPhone 3G
Pioneer sx-315 receiver stays in phones in mode and no sound is coming out of my main speakers
Simply stick the tip of a screwdriver in the input and it will reset. (:
Feb 24, 2008 | Pioneer SX-315
Philips GoGear HDD6330 MP3 Player Logo
163 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
