Question about Kodak EasyShare C743 Digital Camera
Dropped camera in sand...
... Now the lens won't come out when I turn in on. It says, "Lens error: 111, 0, 0, 95." or "111, 0, 0, 87", or "115, 0, 0, 111" etc.... ??? Any suggestions on how to fix it myself? Haha, before I crack it open anyway? I need it this weekend...... =[
  • 2,427 Answers
Maybe because there are some sand particles stuck between the lens mechnisim, you will need to open it up to clean it out.
or the lens may have been pushed too far in, you will need to open it and gently push it back foward only a little,
No i cannot walk you through opening and reassembling since everycamera is different, But
1.) these contain small parts so be very carfeul
2.) do not force or pry apart you will break stuff
3.) remeber where you took the screws out from
4.) be very gentle when pusing holding clips not to break them
5.) do not disassemble more than you need to, just taking out the case may or may not give you axcess to the lens
6.) BE VERY CARFUL
7.) keep alcohol handy ,, for cleaning and for drinking
Posted on Jul 15, 2008
  • Rishi Roshan Ali Jul 15, 2008
    Oh you can try gently tapping and pulling the lens free before you open it up
  • 4,472 Answers
Your best bet is to just open it up and try and blow the sand out but you will want to be very careful.
Hope this helps.
Thanks,
Lee
I dropped this camera accidently in the sand at the beach.I've cleaned it out the best I can but the Lens evidently still has sand particles in it. when I turn on the power it reads "Lens...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 10, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
How do i restart the camera the camera was dropped and lens is out i turn it on and it says lens error restart camera
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Jan 31, 2010 | Canon PowerShot A470 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
I dropped the camera in the sand. I turn it on and it says Lens error OX 04110000
You might try a can of compressed air, but I would see if the camera is still in warranty. I had good luck with my Canon, they sent me a new camera!
Apr 29, 2009 | Sanyo Vpc-s1070w Digital Camera
Having problems with my canon ixus860. When I turn the camera on, the lens can not protract in or out. It's says lens error on screen. Is this a common problem? I don't believe I have dropped this camera...
Oct 12, 2008 | Cameras
Kodak EasyShare C743 Digital Camera Logo
247 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
