Question about LG HBM 730 Bluetooth Headset Wireless Headset
Where to plug in charger?
Sounds like a silly question, but I do not see a port to plug in the charger. I know my eyes are going bad but I don't see an appropriate port.
  • Randi Sue Andrwes Jul 15, 2008
    Okay, I found where to plug it in. The power button has to be flipped open to access the port.
Thank you for posting this I've been trying to figure that out for 15 minutes now, really. Thanks.
Posted on Jul 16, 2008
I have a dragon touch tablet but its not charging. I have to put force and hold it for a long time at a certain angle
Sounds like a bad charger port. If possible find a friend that has as 'like' tablet and see if that charger will work. I don't know of any device that needs to be in a certain position to charge. Since it's charging at an angle and with pressure, then it's probably not the charger, although it could be the part (of the charger cord) that you put into your tablet, usually from a high number of insertions/retractions or abuse.
May 10, 2015 | Dragon Touch Tablets & eReaders
Telecom r100 battery
It could be one of these three things.
1. Bad port. Often in laptops these ports become loose.
2. Bad battery.
3. Bad charger.
Borrowing either a universal power charger, or the charger from someone with a similar laptop, can eliminate some of the possibilities unless it is indeed your charging port.
If after plugging it in, the battery charges you know you had a bad charger. If the battery fails to charge, you know its time for a new battery. Again this only if the port itself is not bad.
Universal chargers can be expensive. You can find batteries and chargers on Ebay for a decent price.
Mar 01, 2014 | Dell Computers & Internet
Battery will not charge
silly question but have you tried a different charger maybe the plug is worn hopefully not on the tab
Nov 19, 2013 | Samsung Galaxy Tab Tablet PC
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I GOT A WA3512 .1 BATTERY REPLACEMENT --AFTER 4 WEEKS, IT IS NOW NOT TAKING A CHARGE. THE RED LIGHT ON THE CHARGER IS BLINKING.
Not only do the batteries go bad, but the chargers as well. If you can, plug in the charger, don't connect the battery to it and test the voltage output with a volt/ohm meter. This should let you know if indeed, the charger is bad. Chargers get hot and don't last forever.
Sep 11, 2011 | Garden
MY LG OPTIMUS PHONE WONT CHARGE OR TURN ON
It sounds like your battery may be shorted and not hold any power, or, the charger is bad. Try a different battery, if you have one. Or, if you have a USB cord for it, plug it into a USB port for the night and see if it charges. That would indicate that your charger was bad. Battery most likely though. Sometimes they just get weak and don't last as long as they originally did, and, sometimes they short out and quit completely.
Jul 19, 2011 | Kitchen Ranges
I have an HP Pavilion dv6 1030us, and I replaced the fan due it going bad, and also the touchpad, and everything worked fine, till I started trying to turn it on, it gets all the way up, and i can enter my...
When you replaced the fan, did you clean off the old thermal compound from the processor and other chips and replace it with a fresh layer? It sounds like your computer is shutting down due to heat. Also, did you remember to plug the new fan into its connector on the motherboard? I know it sounds silly, but sometimes people forget, or don't seat the plug all the way and it comes loose.
There's also the possibility that the motherboard suffered some heat damage before you replaced the fan, but check the other things first.
Jul 09, 2011 | HP Pavilion dv6-1030us Notebook
HOW DO I CHARGE A MERITS DMA SCOOTER?
With the battery charger lol I don't know if your scooter has the battery pack or not but if it does there should be a charger port located on the battery pack just plug the charger into the port and let it charge overnight. If it doesn't have the battery pack then there should be a port located on the tiller usually under the throttle levers Hope this helps
May 09, 2011 | Health & Beauty
Batteries were not holding a charge so I replaced them. Brand new batteries and it is still not holding a charge long enough. I lose one green light within minutes of turning it on after charging all...
Sounds like you have a bad charger. If you have an on board charger, plug it in to the wall and test the voltage at the charger port at the front of the joystick between pins 1 and 2 (the two eyes of a happy face). If you get between 26 and 28 volts and the voltage rises as you charge, then the on-board charger is OK. If not check the AC cord and connections to the charger, including the lego black block and/or connection of the charger at the controller. The type of connection depends on year and serial number.
If you have an off -board charger plugged into the front of the joystick, check your voltage directly at the batteries with the seat flipped back. With the off-board charger plugged into the front of the joystick measure the voltage being applied to the batteries at the large black 2 pin plug coming from the controller to the batteries. When you take this measurement leave the plug connected and put your digital voltmeter probes in the connector at the back (non-contact side). With the charger on, voltage should read between 26 and 28 Volts or come to that voltage after some time.
On board chargers run about $200 and off board chargers around $300.
Invest in a good AC cord if yours is questionable. For $8, I have fixed many of these chargers with a new AC cord from Radio Shack. Hope this helps.
Jan 26, 2011 | Invacare Pronto M51 Power Wheelchair
My casio boulder will not charge how do I fix it
Hi, you can check with another charger first to know exactly what the problem really is before you can take the next step .Also check the phone on another charger.
After checking with another charger, if charger work,that means the charging sport where you plug in the charger is not working and need to be replaced.
If when you check the charger with another phone and and the charger doesn't work, replace charger.
Take care.
Jun 15, 2010 | Casio G'zOne Boulder Cell Phone
LG HBM 730 Bluetooth Headset Wireless Headset Logo
Top LG Radio Communications Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
sonic boom...
sonic boom...
vimal
vimal
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
