Question about Cameras
Dropped in sand, lens won't come out when turned on...
  • 2,427 Answers
Maybe because there are some sand particles stuck between the lens mechnisim, you will need to open it up to clean it out.
or the lens may have been pushed too far in, you will need to open it and gently push it back foward only a little,
No i cannot walk you through opening and reassembling since everycamera is different, But
1.) these contain small parts so be very carfeul
2.) do not force or pry apart you will break stuff
3.) remeber where you took the screws out from
4.) be very gentle when pusing holding clips not to break them
5.) do not disassemble more than you need to, just taking out the case may or may not give you axcess to the lens
6.) BE VERY CARFUL
7.) keep alcohol handy ,, for cleaning and for drinking
Posted on Jul 15, 2008
  • Rishi Roshan Ali Jul 15, 2008
    if you can grip it with your fingers , try pulling the lens out when turning the cam on
  • Rishi Roshan Ali Jul 17, 2008
    hey any luck
  • 4,472 Answers
Definitely got sand in the lens mechanisms. Are you trying to take this camera apart yourself? You also may be able to get it serviced locally for fairly cheap.
Hope this helps.
Thanks,
Lee
Lumix tz8 won't turn on
Are you saying that there's no electrical power at all? Or do you mean that the camera won't complete its startup sequence, and gives you an error? I'll assume the second first, as that is more common:Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
But if you really meant that the camera is not showing any electrical power at all, then see this.
Nov 11, 2011 | Panasonic Lumix DMC-ZS5 / DMC-TZ8 Digital...
I dropped this camera accidently in the sand at the beach.I've cleaned it out the best I can but the Lens evidently still has sand particles in it. when I turn on the power it reads "Lens...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 10, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
I dropped the camera in the sand. I turn it on and it says Lens error OX 04110000
You might try a can of compressed air, but I would see if the camera is still in warranty. I had good luck with my Canon, they sent me a new camera!
Apr 29, 2009 | Sanyo Vpc-s1070w Digital Camera
Sand in my camera
Sand, water, salt water, dirt and dust can damage the lens to the point of no return, so to speak.
It may not have been dropped if you had used the wrist strap, how ever it is now in damaged condition.
The lens needs to be taken apart to completely clean out the sand. This is a very tedious and is a job for a professional with experience.
The parts are extremely small and have close tolerances, thus any dirt or sand can cause grinding or damage to the internal parts of the lens mechanism.
If you ever get a chance to see the gears and the gear teeth, you would understand why just a few grains of sand can jam these small parts. One grain of sand can stop a lens gear from working and possibly cause a broken gear. The parts are so small that in order to see the grains of sand which cause the problem, it may be necessary to use a magnifier lens.
To even make things worse, there is grease usually on the gears. The grease will hold any sand and cause it to stick in place. Cleaning these gears is not very easy.
I have done it, and returned the camera to working condition, but not an easy job.
Aug 30, 2008 | Nikon COOLPIX L3 Digital Camera
Camera
clean off the lens and any other open areas when you dropped it..
Aug 08, 2008 | Cameras
Dropped fe- 230 camera in sand..spazzing out..help ASAP please
Borrow a friends camera or buy another.
The motorized lens assembly is contaminated, and
your only recourse is to replace the entire assembly.
It has very close tolerances and even replacing it is no guarantee that all the sand particles could be cleaned out of the camera body.
Sorry. No easy fix this time.
Regards Paul
May 30, 2008 | Olympus FE-230 Digital Camera
Cameras Logo
276 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
