For downloading driver software, please visit the HP
site page : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3651156.
On this page, please select your OS and click next. Now, there will be
option called "Driver - Product installation software" section, expand
and select appropriate version you need to install and you will be taken
to download page. Before installing, just remove previous software, if
installed (recommended).
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
Check the BIOS to see if you can make the USB as the first boot device, if you can then you will be able to install XP from the USB flash memory stick. The reason why your XP installation failed is because in most older laptops, the USB port does not work until Windows XP has been installed. Your hard disk may have an Windows XP install partition that you can access to reinstall Windows, provided you have not deleted this partition.
Normal
0
If you printer does not have a built-in network card then for the laptop and computer to print via wireless to this printer either then, the printer needs to be connected to a print server or setup as a shared printer. A shared printer is the cheapest and easiest option. Please click on this link and follow my instructions to setup a shared printer :- http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
I have to ask this question of you, just to make sure this is not an issue.Are you using a factory new ink or toner cartridge? Please consider the following: If you are using a refilled (theabsolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem.Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges. They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors. If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges Don
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers http://h18000.www1.hp.com/cpq-country/cpq_support.html
