Please tell me which problem you are facing ? Describe your problem properlyPlease tell me which problem you are facing ? Describe your problem properly
You can't post conmments that contain an email address.
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
once you have the mobile conection pluged into your ps3 try scanning 4 networks if it finds ur network click onto it and type in the WPA key that came wit your mobile conection
PLZ RATE THIS IF YOU FIND IT HELPED SOLVE YOUR CONECTION TANKS.
For connecting your mac computer you may need to configure router . What you can do you call call linksys Free Technical support - Direct number is 1800-326-7114
Not if Wifi connection is turned off. You may need to get a new connection and be able to keep the old one for no price. I dont know how to create a new wireless "wifi" allowed net, so you may need to ask around for help.
Do you mean 3g mobile broadband , have you usb modem ore pc card. What is the problem ? are the software? ore are the conection to the nettverk?what sort of card and nettverk?
AOL does not support Linux, so you cannot install their software. Did you tell them you had a Linux PC?
To help further you must explain what your 'network' is.
Do you have a wireless network or do you use ethernet cable?
You should be able to have internet access without needing AOL software.
Please give details of your network and equipment.
Thanks
S
