Keep gettin A600 error message on my printer - Office Equipment & Supplies
  • Anonymous Apr 01, 2009
    Canon all in one MP530 , error message A600
    suggestions for solution/fix
    Sergeant:
  • 154 Answers
6A00 fix
There is a sponge to the right of the ink cart that gets pushed up to prime each ink cart. The sponge then drops back down when finished. The problem is that the sponge gets stuck up. Just give it a tap and it will fall down, turn off then on and all fixed
Posted on Oct 21, 2008
I did have a paper jam a couple days ago and am now getting a a600 error code on my mp530, any suggestions on how to reset this?
A600 is a generic error message of a Canon Printer that points out to a hardware issue. No specific part is referred to so it's difficult to tell. You need to take this to the nearest service center to be checked and repaired, as what Canon techs advise.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment in return. Have a good one!
Jul 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Getting error code on printer screen A600 why does
Mine kept doing that. My dad found website where lots of people had turned it upside down, shook it and then was fixed, so we tried it and it actually worked!! Now is printing again and no error codes!! Worth a try!!
Feb 09, 2011 | Canon PIXMA MP600R All-In-One InkJet...
Error message, printhead missing or not installed or has come loose. The printhead is in place, I removed the cartriges and removed the printhead then replaced them with the same results
help! I am looking for the solution! I also have a broken arm and i keep gettin timed out. Error message, printhead missing or not installed or has come loose.The printhead is in place, I removed the cartriges and removed the printhead then replaced them with the same results. I you can respond please instruct me whay to do. i have had my printer out for 10 days. ps, my phone number is 931 993 8269 email is jiyoung@fpunet.com
Dec 23, 2010 | Kodak ESP 5 Printer
The cartridge holder won't slide along - just says error message A600. Had just replaced a cartridge, and it did work at first, but not 5 mins later
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
I will keep on helping.
All The Best: Pineworks
Mar 22, 2010 | Canon MP610 Photo All-In-One Printer
Pixma MP610 Error A600
The code is for a cartridge lift mechanism error. Either the sheet feed unit, logic board or pr lift shaft assembly.
Feb 24, 2010 | Canon PIXMA MP610 InkJet Printer
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Oct 07, 2009 | Canon Office Equipment & Supplies
I receives error message A600 on my printer
6A00 fix
Oct 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
CARD NOT INITIALIZED.
You will have to format it. Keep it in the camera and go through the manual's instructions for doing this, sorry but this sometimes happens.
Dec 18, 2007 | Fuji FinePix A600 Digital Camera
230 people viewed this question
jasbo
jasbo
