Question about Frigidaire FRS26R4A Side by Side Refrigerator
Fridgedaire doesn't cool till unplugged
My refridgerator stops cooling the actual fridge, the freezer gets very cold, but does not freeze. Someone told me to unplug it and let it stand for a day or so and then plug it back in. This did work, but I am having to do it more frequently. Is this a problem part that can easily be replaced? This is not a side by side, it has a top freezer.
Tonya
  • cherokeetlf Jul 15, 2008
    Frigidaire stops keeping things cold, freezer stops freezing but is very cold, though they both will work once it is unplugged for about a day and then plugged back in. Having to do it more frequently lately, wondering if this is a part that I can order and replace myself.
  • cherokeetlf Jul 29, 2008
    After unplugging, the both compartments cool just fine, however, after about a day, the frost starts building up again until i need to restart the process. I have black coils that run up the back of the fridg, are these the condenser? They are clean and dust free.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
if this helps please giv a fixya vote
Posted on Jul 15, 2008
Take the refigerator and get out the house and paid a new one
Posted on Sep 05, 2008
Take
Freezer works/ refridgerator doesn't cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Refrigerators
Refridgerator freezes up on back wall
heatman101
Mar 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice building up on back walls of freezer refridgerator seems then not cold enough or bottom drawer freezing produce
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Frigidaire Refrigerators
Freezer is freezing but refridgerator is warm
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 07, 2010 | Whirlpool GS6SHEXNL Side by Side...
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
Oct 27, 2008 | Kenmore 50522 / 50524 Side by Side...
Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Feb 06, 2008 | Samsung RS2556 Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
388 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
