Question about Microsoft Word 2003 for Students & Teachers (B00030EZJE)
Disk data is in read only mode. How change to Read/Write?
    Novelist:
    Scholar:
  • 160 Answers
If you are referring to files on a CD, they are read only because a CD does not allow you to write on it after it has been created.
You need to copy the file from the CD to your hard drive, edit, and resave it there.
If the file is already on your hard drive and is read only, you can right click on the file name, and select Properties. Clear the "Read Only" check box and choose OK.
Posted on Jul 18, 2008
Specifications nec fd 1137c
what are you looking for? Here is what I have:
LED Indicator: Green
Interface Connector: 34-pin connector right-angled header connector
Operation Mode Write / Read: 2MB mode / 1.6MB mode / 1MB mode
Disk Used
(90mm / 3.5): High density (2HD) / High density (2HD) / Normal density (2DD)
Data Transfer Rate: 500KBps / 500KBps / 250KBps
Unformatted Data Capacity: 2MB / 1.6MB / 1MB
Rotational Speed: 300rpm / 360rpm / 300rpm
Track Density: 5.3 track/mm (135tpi)
Track to Track Time: 3ms
Required Power: +5V single (4.5V ~ 5.5V)
Signal Output Driver: Open Collector TTL
Input signal Pull-up: 1K Ohm 30%
Function Setting at Delivery: Interface Setting:Pin2: MODE SELECT input (LOW: 1.6MB mode) Pin12: DRIVE SELECT 1 input Pin34: DISK CHANGE Output Other Function Setting: 1. Automatic density setting for 2DD (1MB) disk or 2HD (1.6MB/2MB) disk 2. LED Turn on Condition: DRIVE SELECT 3. Motor Rotating Condition: MOTOR ON 4. Ready and seek-complete gate (full-mask) for INDEX and READ DATA output pulses 5. Auto-chucking at disk installation 6. Auto-recalibration at power on 7. Frame is electrically shorted to DC 0V
Dimensions: 101.6 W X 25.4 H X 145 D mm excluding front bezel
Weight: 345g
Mounting: Vertical/horizontal with spindle motor down
MTBF: 30,000 POH
Safety Standards: UL, CSA, TUV
May 27, 2014 | Teac Computers & Internet
Write protected
Hi there.
I assume you are using Microsoft as an operating system.
You may need to run a filesystem check on the disk. Some times windows protects data by putting the disk in a read-only mode if your server/machines rebooted/shutdown unsafely.
Run it 2 or 3 times and you should be able to read and write to the disk again.
Dec 06, 2013 | Computers & Internet
I do not know what to do says Please insert PlayStation or PlayStation 2 format disc. Please read it if you write to me with otgovor.A'm desperate.
if the disk is a Blueback, most modern PS2 consoles won't touch it. bluebacked disks still have their data stored in CD format rather than in a Data DVD
to play a Blueback
1. turn on the unit without a disk in
2. press Triangle on "browser"
3. scroll up to the top item and press triangle again
4. turn "Diagnostic Mode" ON
5. back out with circle, and start the browser
6. put your disk in with the browser on. is should read the disk
some disks will still cause the red screen (like cheat devices) occasionally
Aug 28, 2011 | Bandai Digital Entertainment One Piece:...
When i try to install the sims 3 File: E:/Chaches/Sunset Valley.objectChache Error: Data error (cyclic redundancy check). pops up i cleaned the disc but it didnt help
If 'E:' is your CD/DVD drive, then some of the data could not be _correctly_ read from the disk.
When the data was written, a CRC value was calculated for the data, and that CRC-value was written onto the disk immediately after the data. When the data is read from the disk, the CRC-value also is read from the disk. A "new" CRC-value is calculated from the data that was read, and the "new" CRC-value is checked against the "old" CRC-value. If the two values do not match, then the data retrieved does *NOT* match the data that was written, i.e., you have an "I/O error".
Take the defective CD-ROM back to the retailer, and get it replaced, under warranty.
Nov 21, 2010 | Computers & Internet
I'm trying to move an mp3 file from the desktop to my flash disk but a pop-up window always appears saying "cyclic redundancy check". what shall i do?
Everytime that you write a block of data to your 'C:' drive, a CRC ("Cyclic Redundancy Check") value is calculated, based on the data, and it is written onto the disk, right after the data.
When you ask to read that data, the CRC also is read from the disk.
A new CRC is calculated from the data that was read.
If the "new" CRC is "checked" against the "old" CRC.
If the two values do not match, then the disk-drive either did not correctly write the data,
or it did not correctly read the data.
So, that part of the disk-drive occupied by your MP3 file is "bad".
It might be a sign that the ENTIRE disk-drive is soon to completely FAIL.
> what shall I do?
Backup all your files to an external storage device, while you still can access your files.
Nov 13, 2010 | Computers & Internet
Not read sata hard disk althought i bought ide sata to data converter but mother board not read the hard
1. ensure under bios setting you have set to "enhance" mode on drive
setting.
2. ensure that all data and DC supply are in good condition
Aug 10, 2010 | Gigabyte GA-6OX Motherboard
Disk read error when booting
when a "disk read error" occurs, it's most probably the disk that crashed. you can try and repair the disk by booting from a bootable cd or USB-stick with diagnostic functions, such as UBCD4win, which can be downloaded for free. UBCD has many functions to check disks for consistency. if this does not help you, then i'm afraid that you will have to replace the disk with a new one. however, it may still be possible to retrieve data from the disk, if you connect it to a pc using a usb-to-ata bridge. the program i use for data retrieval is file scavenger.
Apr 21, 2010 | Gateway MT6451 Notebook
My IBM T41 developed a problem with the wireless radio on network connection with my O2 router. It is OK when hardwired and when the radio is off, but when the radio is enabled, within 2 or 3 mins aftwr...
The disk-drive on your computer is having problems reading data, i.e., it's about to "die".
Sometimes, i.e., when your wireless is enabled, it's trying to read that part of the Windows software that controls the wireless device from the disk-drive,
When Windows writes a block of data to the disk-drive, it calculates a "check-sum" code, using 'ECC', and writes those bytes as well. When Windows reads a block of data from the disk-drive, it recalculates that "check-sum", and compares it with the ECC bytes that also were read from the disk.
A "mismatch" between the "old" and the "new" ECC indicates that the data has _not_ been correctly read from the "sector" (#6310750) of your disk-drive.
Backup your files, contacts, and E-mails, and replace the disk-drive, as soon as possible.
Apr 05, 2010 | IBM ThinkPad T41 Notebook
Matshita dvd ram uj 85js
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
44
Jul 25, 2009 | Lenovo 3000 V100 Notebook
Computers & Internet Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
